Tyre rubbing rear arch on saph
I just fitted a set of rear camber shims and 1 tyre rubs the arch over bumps
Running Escos wheels wih 215 40.
Was fine before even with a car full so its amazing how a 5mm shim can make so much difference
What do you guys do, trim the arches, roll them ?
It could be that the rear beam/diff is not centred under the car. I found the same problem after fitting a new rear beam and arms on mine. I loosened the beam mounts and centre diff mount, pushed the beam across to the near side and tightened up the bolts. It will only move a couple of mm but it was enough to stop my tyre rubbing on the arch.
fuzzy
21
Feb 15, 2016 10:26 PM
turbotrev
14
Sep 6, 2015 10:27 AM
