Cosworth YB coil on plug conversion questions?
Old May 28, 2013 | 08:08 PM
vaughant's Avatar
vaughant
Default Cosworth YB coil on plug conversion questions?
Hi all.
Had a good look on here and t'interweb regarding proper coil on plug conversions and the info seems a touch limited.
In aware ok that yaris 1.3 plugs fit which is great but I'm wondering what to use to drive it?
Is the msd wasted spark kit compatible with these and how do they work?
Is it just worth buying the msd wasted spark kit,keeping the leads and hoping this wont miss fire(which from reading on here it appears it doesn't) and be done with it?
I don't want to go stupid power but I do want it to be as reliable as possible and hassle free (as a cossie gets!!!).
Any advice really appreciated.
Old May 28, 2013 | 10:00 PM
COLEYST200's Avatar
COLEYST200
I'm told you will need a after market ECU to run them Which will cost so if I was you just run the MSD wasted spark kit as it should be run and you will be very happy with it mate I'v run it for 4 years now spot on bit of kit
Old May 29, 2013 | 12:08 AM
vaughant's Avatar
vaughant
Yeah I actually started searching again on here with "coil on plug" in the title and most folk said basically that the msd kit is more than ample for the car.
Need an 044 as well so perhaps a deal can be struck????
Cheers for the advice,good to hear the kit works as well.
Old May 29, 2013 | 07:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
There is always a deal to be made mate. Give us a call.
Old May 29, 2013 | 01:10 PM
markk's Avatar
markk
Love dealing with companies with that type of attitude you cannot go wrong.
Old May 29, 2013 | 10:08 PM
vaughant's Avatar
vaughant
Thanks fella will do, did the connector issues get sorted out as I recall there being a supply problem?
Old May 29, 2013 | 10:38 PM
Sonic Boom's Avatar
Sonic Boom
Hi all.
I tired to get Denso (Yaris) COP's to run in wasted spark format using the MSD board, you certainly get a wasted spark it fires all 4 at the same time with a spark large enough to fell a horse
I've just stuck with it as it was designed with the addition of 40,000 volt MSD coil pack which works perfectly fine.
Rich
Old May 29, 2013 | 10:44 PM
MrC's Avatar
MrC
Ate the wasted spark kits back in stock now stu??
Old May 30, 2013 | 06:39 AM
Jay,'s Avatar
Jay,
Sponsor
Spoke to Stu yesterday and there instock
Old May 30, 2013 | 07:03 AM
timster's Avatar
timster
This is gonna be the next mod on my cossie
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Anutternutter
Aug 21, 2015 06:07 PM
Caddyshack
Aug 19, 2015 07:29 PM
Aug 14, 2015 07:29 AM
