Fuel
Old May 27, 2013 | 10:01 PM
QPHOOP's Avatar
QPHOOP
Default Fuel
Any ideas on the best fuel to use for my 3 door Cossie?
Paul
Old May 27, 2013 | 10:12 PM
Sonic Boom's Avatar
Sonic Boom
Ideally you should put in what you had it mapped on.
I always use Shell V-Power or V-Power Nitro as it's called now.
Rich
Old May 27, 2013 | 10:14 PM
MrC's Avatar
MrC
If you put anything else in other than vpower then you may aswell just piss in your tank.
Old May 27, 2013 | 10:22 PM
QPHOOP's Avatar
QPHOOP
Do you add any additives to the fuel?
Old May 27, 2013 | 10:27 PM
Sonic Boom's Avatar
Sonic Boom
Nope
Rich
Old May 27, 2013 | 10:28 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
V power in mine and its mapped on it
Old May 27, 2013 | 10:46 PM
QPHOOP's Avatar
QPHOOP
Closest one to me is over 10 miles away but its got to be done
Old May 28, 2013 | 11:12 AM
opposite lock's Avatar
opposite lock
Is the shell the same ron as tescos . 99 ron? Surely that would be safe to use aswell.
Old May 28, 2013 | 12:37 PM
martysmartie's Avatar
martysmartie
Rich
This ^^.
If you go lower octane when it's mapped for higher octane it can cause issues such as pinking etc.
As a general rule, FI and other N/A engines like 'SUL' though.
In the case of a 'run of mill' motor though using 'SUL' wouldn't cause any harm, but you wouldn't gain any benefit.
Martin
Old May 28, 2013 | 05:30 PM
cossiedad's Avatar
cossiedad
My mate is a tanker driver and says when he fills his tanker up the Optimax and Tesco super is the same stuff from the same hose. Only difference is the Optimax gets an extra cleaning additive put in at the next pump (he pulls the truck forward and adds the additive at the refinery). For example he gets the Tesco and Optimax from Tank 1 for example and the additive from Tank 2. It is left to mix in the tanker on his journey to the filling station.
cheeRS
Old May 28, 2013 | 06:09 PM
ajamesc's Avatar
ajamesc
When fifth gear did a fuel test the shell v power won by quit a few bhp!
Plus I was lead to be leave that v power was a made fuel and all other makes we're normal unleaded with an additive
Old May 28, 2013 | 06:43 PM
cossiedad's Avatar
cossiedad
I thought the same myself, but he explained it all to me the other day. He's an older gent and is very particular, almost OCD like, so I have no reason to think he would lie. Possibly the additive could be performance enhancing too but definitely the same base fuel.
cheeRS
Old May 28, 2013 | 06:46 PM
ajamesc's Avatar
ajamesc
Is a bit funny what with Ferrari's name on the v power fuel! Plus tesco is a competitor.
I'd have thought Ferrari would pull there name if it was the same after all the spill about it being made along side them for there cars
Old May 28, 2013 | 08:25 PM
LHD220Turbo's Avatar
LHD220Turbo
Paul
has your car been live mapped?
if not, then most chips, like MSD will only insist on 97+ RON rated fuel
Old May 28, 2013 | 10:24 PM
QPHOOP's Avatar
QPHOOP
Its been remapped by Graham Goode stage 1 285 BHP
Old May 29, 2013 | 04:39 PM
LHD220Turbo
if its just a stage 1 chip then i suspect 97+ rated fuel will be OK, but if you ring GGR they will tell you what fuel the chip is designed for
Old May 29, 2013 | 06:26 PM
V power.Im sure its got the highest octane out of them all.
Old May 29, 2013 | 07:18 PM
MrC's Avatar
MrC
Actually BP do the highest octane, at 102ron, but it's only available at certain stations.
Old May 29, 2013 | 08:56 PM
Sonic Boom's Avatar
Sonic Boom
Ye and it's about 249.9p a litre!
Rich
Old May 30, 2013 | 09:16 PM
Cossy Mike's Avatar
Cossy Mike
Ran mine on standard 95ron UL for 4 years without issue as the manual said
Old May 30, 2013 | 09:19 PM
LHD220Turbo
no problem if the car is standard
Old May 30, 2013 | 10:13 PM
matthewpickup's Avatar
matthewpickup
if I use Tesco type fuel (only if really really stuck) my engine will pink but with v-power its fine , not tried BP but I would only really use shell or BP
Old May 31, 2013 | 03:24 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
In my country there is 95 RON and 98 RON fuels, and I always use the 98. There's also Shell V-Power Nitro+ but it's also 98 RON and identical to normal 98 exept for few additives which probably have no big effect on the engine... Couple years ago V-Power was still 99 RON but not anymore. I take it that normal gas in UK is 97 RON, but what is the RON octane rating for V-power in your country?
We also have few gas stations with E85 which is common fuel in tuned turbo engines here...
Old May 31, 2013 | 04:39 PM
LHD220Turbo
95 ron is standard unleaded in the UK
97 is the esso & BP super unleaded
and then V power
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
