air leak under inlet manifold any ideas
Old Mar 16, 2005 | 05:58 PM
S1 JOHN's Avatar
S1 JOHN
Default air leak under inlet manifold any ideas
large hissin noise from under inlet manifold checked and replaced all little vac pipes when you pull on the one that goes under neath the manifold out of the t piece in the centre it quitens down what does this connect too any body else had this problem
the car is a n reg scort cossie with big turbo conversion
Old Mar 16, 2005 | 06:22 PM
Glenn5's Avatar
Glenn5
inlet throttle body plenum gaskets thats the favourite 1s m8
Old Mar 16, 2005 | 06:24 PM
S1 JOHN's Avatar
S1 JOHN
thats what i thought but when u squeeze that hose to stop the air gettin through the noise goes ?
Derek Burleigh
Sep 16, 2015 06:27 PM
Russ Hill
Aug 31, 2015 06:44 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
turbobill
Aug 9, 2015 05:21 PM
