Supra diff, realistic price?
Old May 19, 2013 | 03:42 PM
WongRS's Avatar
WongRS
Default Supra diff, realistic price?
So i just blew my 7.5" to pieces, which i was fully expecting to do.
with classic ford only 2 weeks away i'm a bit tight on time, and money isn't amazing at the moment, that said, i don't really want to waste another £200 for a 7.5" when it'll just blow up again.
So, realistically, how much do i need to do a supra diff from start to finish?
Old May 19, 2013 | 04:20 PM
DAN400's Avatar
DAN400
£650?
fitting kit is £500 odd and allow £150 for a diff
its a cheap conversion imo
Old May 19, 2013 | 04:27 PM
WongRS's Avatar
WongRS
Hmm. Tempting. Not sure it would be done in 2 weeks though.
Old May 19, 2013 | 04:38 PM
doga-ot's Avatar
doga-ot
Yeah it is cheap yes its worth doing and yes you will reap the benefits but and yes theres always a but..... No chance of having it done in 2weeks you will have to order an mk mountings which are made to order, wait for delivery and then find the correct supra diff and have it delivered then fit it all! Contact Gary@rsclassics should get a diff for £100
Old May 19, 2013 | 04:39 PM
doga-ot's Avatar
doga-ot
Then save and go the supra route
Old May 19, 2013 | 04:46 PM
WongRS's Avatar
WongRS
I'll give him a try, standard is going to be the only choice I guess.
Old May 19, 2013 | 04:48 PM
JamesH's Avatar
JamesH
A while ago Tony had the Supra fitting kits on the shelf
Old May 19, 2013 | 05:01 PM
WongRS's Avatar
WongRS
The ones that John was knocking up? Any idea on his price?
Old May 19, 2013 | 05:13 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Tony doesn't make them anymore, I had the last one.
Old May 19, 2013 | 05:50 PM
BRAMMER's Avatar
BRAMMER
I thought Marks kit was going to be more expensive after the initial group buy.
diffs have risen in price too as folk have realised the fords use them
for a complete kit your going to be looking more toward £7-800
Old May 19, 2013 | 08:14 PM
mark r's Avatar
mark r
I had marks last kit cost me 700 with a diff he had
mark
Old May 20, 2013 | 05:17 AM
akamob's Avatar
akamob
mark
You got it yet?
Old May 20, 2013 | 06:57 AM
scoooby slayer's Avatar
scoooby slayer
what about a bara diff like sonic boom has
Old May 20, 2013 | 07:58 AM
doga-ot's Avatar
doga-ot
The only 2 options really are supra diff kit or 7.5" bara diff
Anything else not really worth the look to be honest as these are the only 2 to be proven to taken the power, i am yet to hear stories of bara diffs imploding in big numbers where as quaife and gripper do and i have heard of many cases
Old May 20, 2013 | 08:01 AM
doga-ot's Avatar
doga-ot
Its £400 for a bara but you supply the diff
Old May 20, 2013 | 08:51 AM
XRT_si's Avatar
XRT_si
What did you break on the diff? The gears or the crown wheel/pinion?
Because there's absolutely no point at all in replacing your diff with a Bara, Quaife or anything else if you broke a crown wheel/pinion as the aftermarket diffs still use the original item.
I broke four diffs when I had my RWD Saff and would only look at a Supra diff.
Old May 20, 2013 | 10:11 AM
scoooby slayer
i have blown 4 2wd diffs and everytime it was the planet gears.
im sure ive got a mint crownwheel and pinion somewhere in the workshop
Old May 20, 2013 | 10:25 AM
XRT_si's Avatar
XRT_si
I mostly did planet gears and then started doing the CWP as well.
Old May 20, 2013 | 10:27 AM
WongRS's Avatar
WongRS
It's planet gears I think, it's still trying to drive the ns wheel
Old May 20, 2013 | 10:57 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
What a completely untrue statement. The 10.5" Jaguar conversion is the way to go with really big Power. Not relevant in this case because of cost .
Old May 20, 2013 | 11:13 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
The cases you have herd with a gripper or quaife are the cwp braking which the bora uses the same lol the bora will not be as strong as a gripper or quaife with high torque levels as it still uses 2 plant gears and 2 sun gears which was the standard diffs weekest point!
They may be up rated in the bora but take the gripper which has 2 sun gears and 4 planet gears will be stronger
Best bet for cost effective is the supra best bet full stop is what rod has then the ford Motorsport diff
Old May 20, 2013 | 11:37 AM
doga-ot's Avatar
doga-ot
I always thought the ford motor sport diff was the best option however they are rare as fuck and have the price tag to match!
Old May 20, 2013 | 12:47 PM
gibbo frst's Avatar
gibbo frst
my old bara diff went back 4 times due to different problems . a mate broke his uprated planet gears on his too. weird as mine went in as a quiet standard diff. had the vc pumped up , uprated planet gears and new bearings and turned into a noisy diff..
they were very helpful though and never charged me once even over a 2 year period as the car had done hardly any miles.
I was always worried about it breaking on me again so sold it when rebuilt the last time and got a gripper which I had much more confidence in.
Old May 20, 2013 | 01:07 PM
cossieDavedree's Avatar
cossieDavedree
if you are buying a 2nd hand supra diff then you also got to price up getting it rebuilt as its going to be tired and won't lock up properly.
If you wanted to drive the car just to be on the road and drive to santapod then get another 7.5", and behave yourself or at least dont launch from standstill/slow speeds
if you want to get the car on the road and and launch at santapod on classic ford day then spend the money on a proper diff but you wont do it in 2 weeks
Old May 20, 2013 | 02:21 PM
mark r's Avatar
mark r
Originally Posted by akamob
You got it yet?
just heard from mark its on its way to my couriers..sweet
Old May 20, 2013 | 02:49 PM
mark r's Avatar
mark r
if you got 3K spare!!!!.im not far of that now.my quaife was 1480 euros fitted.then I got it rebuilt with new bearings another 500 euro.then I smashed cwp,another 500 odd with 3.9 cwp shot peened and another rebuild kit from bara,thats like 2.5 k nearly another 500 notes theres a 9" motorsport diff job donecossie ownership
mark
Old May 20, 2013 | 09:19 PM
Sonic Boom's Avatar
Sonic Boom
I'm running 590 bhp and 578 ft/lb of torque now and my Bara diff is still taking mega hard launches on 888's.
Rich
gcfcos
59
Oct 6, 2015 05:04 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
