driveshaft support bearing
Handbrake on put in 1st. Loosen your drive-shaft bolt. Loosen your upper strut mounting bolt 5 turns, loosen wheel nuts. Jack and support on axle stands , I would then drain the gearbox oil. Remove lower arm ball-joint clamp bolt and prise lower arm from hub (use a long bar levered against the underside of the car, do not use a ball-joint separator, as it tends to feck the dust cover. Completely unscrew the drive-shaft nut, then pull the hub outwards to remove the drive-shaft from hub (may need persuading with rubber mallet). Once out tie the end of the shaft in place or support on an axle stand. Undo the support bearing retaining bolts. Pop the drive-shaft out of the gearbox and withdraw from under the vehicle. Remove bearing using a puller.
Reassemble in reverse order and I encourage nice fresh gearbox oil (SAE 75W/90).
cool cheers, I looked on ebay for the bearing which was around £25 then found a complete driveshaft complete with the bearing fitted (asked ebay seller to confirm this first) for £30 which ill get, gonna change the whole shaft as the clutch needs doing soon
yeah it will, its got a grinding noise coming from my side which ive had since just after I bought the car but nothing showed up in the mot to with the wheel bearing and this can be the other place it cud be so gonna change the driveshaft see if that help as doing the cheapest options first
Is it hard to swap complete drive shafts as I think it is the problem with my car. I've had the front bearings replaced so it rules them out now. Yet I still have a very metallic grinding and vibrating and its worse accelerating or braking but constant at a steady speed.
DavidK
Sep 27, 2015 02:55 PM
