No longer forsale...
Old May 15, 2013 | 05:26 PM
BIL N KEL's Avatar
BIL N KEL
Default No longer forsale...
ford sierra sapphire cosworth 2wd 1989
i bought this car as a bare shell in sept 2010 and then used all the parts from my rotten sapphire cosworth to build it up. before i started the rebuild i stripped the underside of all the underseal and checked for any areas that needed attention (one small patch at back of sill). the car was then undersealed and my mate began preparing it for the respray. it was then painted inside and out in the original mercury grey. while this was being done i rebuilt the engine with all new bearings, shells etc to freshen it up as it had done around 50k since it was built. while building the car no expense was spared and every bush, bearing and gaitor was replaced as to try and create as new a car as possible. i sourced a interior from a 50k mile car as my old interior had seen better days. the new interior is in very good condition with very small amount of wear to the drivers seat. all the running gear was removed from my old car and fitted to the new car which included nearly new gaz coilovers, rebuilt gearbox and diff and rebuilt standard calipers with uprated discs and pads. the car was then mot'd and put on the road march 2011. i then used car for weekend use and attending shows and covered around 10k miles until february 2012.
the engine was starting to get an annoying rattle when first started in the morning, so i took the engine out and sent it to joe stevens at bluesprint in essex. he phoned me a couple of days later to tell me that the noise was piston slap and that the bores would need boring out to .25 to get rid of it. i gave the go ahead for a full engine rebuild as there was no point putting it back together with worn parts. this included new cosworth racing forged pistons, oil pump, bearings, shells etc. once i had ran the engine in i took it back down to have the power upgrades fitted and mapped. it was previously running stg3+ around 340bhp on green injectors and t34.48 with the usual rs500 intercooler, uprated breather etc the car was then treated to grey injectors, .48 was swapped for .63 housing and was then mapped to run 2bar of boost giving just shy of 400bhp
i then realised the brakes were not up to the task of stopping the car very well so i bought hi spec monster4 brake kit complete with new discs and pads ( i have a spare pair of rotors too) which improved the braking no end. this caused a problem however as polished rs 7 spoke alloys did not fit over the brakes. I then fitted the 18in mo6 compomotive alloys
quick spec
engine
standard 4x4 head with bd14 inlet cam, 200block machined to except proper longstud conversion, wrc headgasket, .25 cosworth racing forged pistons with valve pockets, all new shells, gaskets, bearings etc grey injectors, 3 bar map sensor, t34.63, grp A breather system, mocal oil cooler, big turbo escort cosworth airbox with k+n panel filter (I also have a big kn cone filter if you like the chatter), baileys turbo damper, scorpion stainless exhaust, all samco hoses boost and water, baileys polished header tank, new 044 pump
transmission
t5 gearbox rebuilt around 30k ago, rebuilt diff 30k, new ap 6 paddle clutch kit 2k
other bits
hi spec 315mm brake conversion, rebuilt 2wd rear brakes, near mint 50k mile interior, boost, oil pressure and afr gauge, turbo timer with boost recall etc new fuel tank and fuel lines
since the new engine has been in it has covered around 5k and since the car has been built it has done about 15k
bad points
the abs doesnt work and the rear arches are bubbling in the usual place and the front bumper is stone chipped (paintwork might be done by time of sale). also it could do with a new fuel pump rewiring kit as the car wouldnt start the other week and there was no power getting to the pump so i made a loom myself from an amp wiring kit. Also the fans have been rewired externally from the fuse box but could really do with a proper msd loom
I loads of pics from the rebuild so if you would like some more please message me
im sure ive missed loads of stuff so if you have any questions please ask.
I'm not really bothered if it sells as I'd happily keep it so no silly offers please
thanks for looking
Billy
Old May 15, 2013 | 05:32 PM
stevecfrst1's Avatar
stevecfrst1
Hi there, im looking for something like this. Where abouts in norfolk are you? Could you pm me your number to have a chat please? Thanks
Old May 15, 2013 | 05:37 PM
Staffi's Avatar
Staffi
That's a peach for someone, already done too.
GLWTS but I'm sure you'll not need it
Old May 15, 2013 | 05:46 PM
lee2cossies's Avatar
lee2cossies
Wow stunning! That won't hang around long at that price. Glws.
Old May 15, 2013 | 07:20 PM
sierrsteve1980's Avatar
sierrsteve1980
Thats a lovely car GLWS and i am going to be cheeky but i have both of the looms for sale that msd used to sell they were made by cw looms.
Old May 15, 2013 | 07:55 PM
KSA-Cossie's Avatar
KSA-Cossie
Always liked this saph, GLWTS mate
Old May 16, 2013 | 11:16 PM
pazzofrst's Avatar
pazzofrst
Very nice saph mate can u pm me ur number interested cheers
Old May 16, 2013 | 11:35 PM
MrC's Avatar
MrC
At last a cossy for sale with tidy engine bay, I don't know why people overlook this as you see mint car all polished up but the bay gets neglected and ends up looking like something salvaged from the titanic
Credit to you mate, GLWTS
Old May 17, 2013 | 06:46 PM
BIL N KEL's Avatar
BIL N KEL
Been thinking about selling it for the last couple of days and decided now is not the time. I was just missing it as hadn't even looked at it since central day. I taxed it yesterday when I got home from work and went out for a blast and found a bit of love again for it so I decided it needs some more toys I went and bought a greddy boost controller earlier and got it fitted so now just need some anti lag and closed loop and that should keep me happy for another 6 months lol
Old May 17, 2013 | 06:51 PM
MrC's Avatar
MrC
Cossy rejection, we all go through it mate
Old May 17, 2013 | 07:46 PM
BIL N KEL's Avatar
BIL N KEL
I was speaking to my cousin the other night and he said he's exactly the same with his rs500. During the winter all he thinks about is selling it but when it comes to show season and he taxes it and starts using it the love comes back and there's no way he'd sell it! Must just be a cossie thing lol
DavidK
Sep 27, 2015 02:55 PM
TC-ST3
Sep 26, 2015 04:47 PM
Ridgey
Sep 13, 2015 08:43 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
