Ford Range This section is for other models in the Ford range.
mustang diff
Old May 13, 2013 | 05:55 PM
mustangsam101's Avatar
mustangsam101
Default mustang diff
hey, i brought my self a 1991 ford mustang fox body with a welded diff and want to change it back to standard or lsd to stop it from wrecking my tires. its only the centre unit that is damaged the crown wheel and half shalfs are not damaged on removal. but its has 10 bolts to hold the crown wheel on 28 splines on the half shafts, i've found that a atlas unit will not fit due to been 8 bolts to hold the crown wheel on. does anyone know if a transit diff has 10 bolts for the crown wheel? any help would be much grateful
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
jonnyenglish
Sep 21, 2015 07:31 AM
Fezman1
Sep 7, 2015 09:34 PM
