Zetec DTA ECU with wideband, braided loom and sensors
I had intended to keep this for some plans I had but unfortunately it needs to go to raise some cash
Nearly new DTA S40 Pro ECU with braided Zetec loom. Its currently setup for a Zetec turbo but will run a NA engine with no problems. It has all the relays with it and is setup to run the fuel pump too.
It comes with an Innovate MTX wideband lambda with gauge, Weber Marelli MAP sensor and a boost control solenoid.
£800 posted, it cost double that for all the bits less than 12 months ago.
JK12
33
Apr 26, 2021 12:09 PM
