Zetec DTA ECU with wideband, braided loom and sensors
Old May 12, 2013 | 09:06 PM
GTi_Tom's Avatar
GTi_Tom
Default Zetec DTA ECU with wideband, braided loom and sensors
I had intended to keep this for some plans I had but unfortunately it needs to go to raise some cash
Nearly new DTA S40 Pro ECU with braided Zetec loom. Its currently setup for a Zetec turbo but will run a NA engine with no problems. It has all the relays with it and is setup to run the fuel pump too.
It comes with an Innovate MTX wideband lambda with gauge, Weber Marelli MAP sensor and a boost control solenoid.
£800 posted, it cost double that for all the bits less than 12 months ago.
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
bigryrs
Sep 7, 2015 06:45 PM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
