Ben Kirby's Supercharged 2.0 Mk3 Fiesta @ M-Tech Automotive
May 2, 2013 | 02:24 PM
Looks like its gona be a intresting lil project.standard internals?
May 2, 2013 | 02:40 PM
*** Sierra RS Custard ***
Nice fabrication work as always
May 2, 2013 | 03:24 PM
So where will the alternator be mounted on this set up the rear? or above the charger?
I've seen one of these done before but the charger was mounted infront of the coil pack with a shaft running across the front of the engine
May 2, 2013 | 03:33 PM
like this
May 2, 2013 | 04:19 PM
Nice project! Will be watching this closely, fabrication work looks good too
What happened to the old engine?
May 3, 2013 | 11:15 AM
Quote:
Originally Posted by
M-Tech Automotive
Ben, yes we were considering using a jack shaft, but instead, a very small alternator, and custom exhaust manifold
Suppose that makes sense for plumbing in the intercooler. I personally would use a sleeved shaft could you imagine catching something in that even at idle speed
May 3, 2013 | 11:49 AM
M-Tech Automotive
Cheers Chip... hows things with you, clio wise etc?
Great thanks mate.
This is my (mtec ecu controlled
) clio turbo versus an M3 at bedford:
The way it left him for dead on the straight even surprised me, it is proper effortlessly quick.
May 3, 2013 | 02:10 PM
Haha nice lil vid chip,what sorta power that clio making? Left the m3
May 3, 2013 | 04:33 PM
like this? 420 hp @ 1755ccm
May 3, 2013 | 09:24 PM
May 7, 2013 | 11:49 AM
RS16iDale
308bhp last time it was on the rollers which was at tipton garage for a clio shootout.
Its a fair bit lighter than an m3 though of course, and less transmission losses.
May 7, 2013 | 01:05 PM
Jun 13, 2013 | 09:26 AM
That will be no drama.
Some tubes, a welder, a bloke in flat cap, sorted.
Jun 13, 2013 | 09:20 PM
You can always trust a man with a flat cap to weld properly. Its like having your own Fred dibna.
liamT74
Sep 23, 2015 10:24 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Brian
Sep 11, 2015 08:06 AM
Ben26
Sep 3, 2015 07:55 PM
