Mondeo Turbo Diesel not starting any idea's?
Old Mar 15, 2005 | 07:44 PM
Big Andy W's Avatar
Big Andy W
Default Mondeo Turbo Diesel not starting any idea's?
its a bag of shit 95 model!
Its got fuel in!
had new heater plugs!
heater plug relay is working!
There is fuel at injector head!
and smokes while cranking if foot is on the gas!
Camshaft ain't snapped!
any ideas before i torch the fuckin crock!
Old Mar 15, 2005 | 08:04 PM
Rob Virgo's Avatar
Rob Virgo
try pulling the fuel line of the front of the filter housing.two lines facing you and its the top one.crank the engine and leave a little fuel out
reconnect pipe and crank engine as normal.
if you got air and fuel when bleedin it should start.
thats the priming head and where the button is to prime/pressurise the system is leaks.
this then leaves air into the system which is death to a diesel
hope it sorts it , did mine recently and its a common problem.
new one from ford built up was 65 euro and is cheaper than spurious
rob
Old Mar 15, 2005 | 08:12 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Could be the engine stop solenoid, had this problem with an escort, was just a broken wire
Old Mar 15, 2005 | 08:13 PM
DazC's Avatar
DazC
It's just you. You manage to break everything!!
Old Mar 15, 2005 | 08:25 PM
Big Andy W's Avatar
Big Andy W
I've cracked the injector nuts off and its spurting diesel out when its cranking!!
Is this a fuel cut solenoid? as there appears to be fuel at the injector and smoke with full throttle while cranking?
Tell me about it i've only just fixed the other fooking car!! at least i'm looking cool sitting in traffic on my way home from work!!
Old Mar 15, 2005 | 08:56 PM
DazC's Avatar
DazC
Jumped pump/valve timing or lack of compression....
Old Mar 15, 2005 | 09:03 PM
Big Andy W's Avatar
Big Andy W
Thats wot my dad recons and he had same when his Citreon jumped a tooth!!
New belt time i think!!
Old Mar 15, 2005 | 09:19 PM
Turbo lag's Avatar
Turbo lag
Andy answer your fooking phone
and can you come round thursday ?
Dave.
Old Mar 15, 2005 | 09:26 PM
Big Andy W's Avatar
Big Andy W
NO my hands were covered in shit!!
maybe but fixing that crock is more important before some one drops a fooking huge beam on my escort at work!!
Old Mar 15, 2005 | 09:48 PM
TrickyDicky's Avatar
TrickyDicky
if theres plumes of smoke while cranking and at tickover then its pump timing.
whip the cover off and loosen 3 bolts on pulley-twist one way and tighten and try that!
Old Mar 15, 2005 | 09:52 PM
DazC's Avatar
DazC
Only do that if the belts have not jumped a tooth. To be honest, even if the belts haven't jumepd a tooth then it should still start, just run badly.
There are 2 timing belts on the diesels. 1 for the cam and 1 for the pump.
Old Mar 15, 2005 | 09:53 PM
Big Andy W's Avatar
Big Andy W
Is ther potential for me to do damage it if do it wrong? I'm a bit paranoid at the mo!!
Old Mar 15, 2005 | 09:58 PM
Ian M's Avatar
Ian M
YES!!!!!!!!!!
Old Mar 15, 2005 | 10:18 PM
DazC's Avatar
DazC
Agree with the old man. Don't fooking touch it if you don't know what you are doing.
Old Mar 15, 2005 | 10:24 PM
Big Andy W's Avatar
Big Andy W
I'll leave it alone me thinks!!
Old Mar 15, 2005 | 10:39 PM
DazC's Avatar
DazC
I don't have a set of timing pins either....
Old Mar 15, 2005 | 10:50 PM
Big Andy W's Avatar
Big Andy W
Thank fuck!! Wouldn't know wot the fook to do with them!!
Fookin Cat Weasels! didn't think they broke down!!
Old Mar 15, 2005 | 10:53 PM
DazC's Avatar
DazC
They still need maintaining you know!
Timing pins are to time the fooker up with. You slot the ends into various holes. I thought you would have jumped at the chance!
Old Mar 15, 2005 | 10:55 PM
MickB's Avatar
MickB
Check glow plugs are actualy working,also check the big fuses near the battery.
Old Mar 16, 2005 | 11:40 AM
James's Avatar
James
Yeah as he said, dissconnect the wires from the glow plugs and with a testlight, place the teslight wire on the positive terminal on the battery and put the probe on the electrical connection on the glow plug. If the test light lights then that plug is down.
Old Mar 16, 2005 | 08:30 PM
Big Andy W's Avatar
Big Andy W
Its just one continuios wire and when the relay clicks its showing correct voltage with multimeter!!
Old Mar 16, 2005 | 08:52 PM
Turbo lag's Avatar
Turbo lag
are you coming round tomorrow Andy
Old Mar 16, 2005 | 09:26 PM
Big Andy W's Avatar
Big Andy W
maybe fitting new belt to the beast, give me a ring tomorrow afternoon!!
Old Mar 17, 2005 | 12:44 PM
James's Avatar
James
Yeah but all you are testing there is that the glow plug relay & supply is all ok & working, the plugs themselves could still be knackered and to determine this you need to do as i said above!
Old Mar 17, 2005 | 05:37 PM
Big Andy W's Avatar
Big Andy W
They have been replaced with new ones!! i mentioned this at the start of the post!!
Old Mar 17, 2005 | 10:10 PM
DazC's Avatar
DazC
Is it fixed yet?
Old Mar 19, 2005 | 12:08 AM
AJC's Avatar
AJC
tell me about it, im checking to see who parks next to me so i know who
might put potential dints in it,
you should be ok in corner of the car park though
Old Mar 19, 2005 | 01:54 PM
Big Andy W's Avatar
Big Andy W
Thats why i park it there!! Park yours next to mine and then only on side may get biffed!!
Fordmad!
Sep 26, 2015 05:24 PM
druidgetafix
Aug 15, 2015 10:22 AM
taylora1409
Aug 12, 2015 12:06 PM
xr_craig
Aug 7, 2015 06:00 PM
ginger1979
Jul 31, 2015 09:56 PM
