Mondeo Fog Light Conversion
hello
i have a mk 3 on a 51 plate with no fogs
what do i need to do to fit front fogs?
i understand the wiring may be there
how hard is it to fit them and will i need a change of switch in the dash?
You need the fog lights (obviously), a section of loom, and a two position dash switch (pulls out once for front, out twice for front and rear)
The loom section looks like this...
Fit the dash switch which is a direct swap, then fit the section of loom from the fog light to a red plug that will already be there on the inner wing. It's all straightforward stuff, and shouldn't take that long.
Dr. Ickxs
Sep 15, 2015 10:15 PM
