Smokestone Cosworth 4x4 to 2wd Project update 10/5/14 painted inlet
Old Apr 25, 2013 | 09:39 PM
RSCossieGaz's Avatar
RSCossieGaz
Default Smokestone Cosworth 4x4 to 2wd Project update 10/5/14 painted inlet
After alittle break from Ford's just after new year i picked up another cossie.Got this 1993 smokestone sapphire cosworth 4x4 which came complete apart from engine,front brakes and ecu.As i still have a pukka 2wd yb engine sitting in the garage and a complete 2wd axle front end along with afew other 2wd bits left over from the last cossie i broke there was only one way to go and thats off all the 4x4 parts that i dont need and replace with 2wd parts.
As im replacing parts i be painting them or cleaning as i go along just to tidy up the car,not going full concourse or anything like that but just want to make it presentable etc.
Heres picture of it day i got it in its new home
1st thing i done on the car was get hold of another bulkhead firewall panel as the one that was on the car was well rotten and rusted.Manage to get one off someone on here which was in alot better nick then the old one so got that off and gave the new one a quick tidy up and sprayed it nice gloss black.
Old one fell apart as it was removed
More progress to follow.
Old Apr 26, 2013 | 07:01 AM
jason_nike's Avatar
jason_nike
Nice project to play with
Old Apr 26, 2013 | 07:12 AM
Cool.Will be keeping an eye on this.
Old Apr 26, 2013 | 08:29 PM
costina's Avatar
costina
Live long and prosper!!
Glad to see that one being saved
Old Apr 26, 2013 | 10:24 PM
RSCossieGaz
Stripped down the 2wd front end i had so can paint and clean everything before i reasemble back onto car.
First of all grinded the loose rust on the anti roll bar,primered it then sprayed it gloss black.
After
Old Apr 26, 2013 | 10:30 PM
RSCossieGaz
2wd front hubs have been painted again gloss black,looks alot better then they did before.
All painted
Old Apr 26, 2013 | 11:32 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Cool. Nice colour too . Look forward to updates on this one.
Old Apr 27, 2013 | 11:33 AM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
A lot more to come Gaz this is the first time ive actually seen you proper interested in doing your cars
Old Apr 27, 2013 | 08:04 PM
fezzajsy's Avatar
fezzajsy
Old Apr 27, 2013 | 08:43 PM
RSLUBBY's Avatar
RSLUBBY
Love smoke stone cozzie s keep the updates coming gaz good to see you back
Old Apr 28, 2013 | 10:25 PM
RSCossieGaz
Will update as i go along for sure,hows ur escos Ian done anything more to it?
Old May 2, 2013 | 07:48 PM
RSCossieGaz
Found a pair of Tca's in the garage that ive had for awhile which fortunatley had powerflex poly bushes in,even thou they were in good condition i thought i would give them a fresh coat of paint.So masked up the bushes and spayed them with hammerite smooth black.
Afew coats later and after they had dried.
Old May 2, 2013 | 08:01 PM
RSCossieGaz
Next up its tackling the steering rack and crossmember craddle,removed the rack from the craddle.
Gave the craddle a quick clean up and primed exposed areas
Then sprayed it couple of coats of gloss black
Its not mint but im happy with way its come out certainly freshened up abit more now.
Next is to sort out the steering rack!
Old May 4, 2013 | 06:49 AM
L1AM_RS's Avatar
L1AM_RS
Looking good chap, Cant wait to pick mine up
Old May 4, 2013 | 11:13 AM
RSCossieGaz
Yeah im back lol cant wait to get it back on the road
Old May 4, 2013 | 11:14 AM
RSCossieGaz
Nice one! You got a smokestone one too?
Old May 5, 2013 | 11:05 AM
Cool progress.
Old May 5, 2013 | 11:26 AM
chowfornow's Avatar
chowfornow
Looking good so far mate, keep theirs coming
Old May 5, 2013 | 09:12 PM
RSCossieGaz
Next up was to clean up the steering rack which had abit of surface rust and generaly looked weathered etc.
So got the dremel out and sanded out all the surface rust and generaly cleaned up the rest of the rack ready for spraying.Got some gloss black hammerite and painted the rack,once that had fully dried next up was to paint the pipes silver.
Im pretty pleased how it turned out
Old May 5, 2013 | 09:16 PM
Rsmat's Avatar
Rsmat
Looking good work mate ... Keep it up
Old May 5, 2013 | 10:02 PM
RSCossieGaz
While i was waiting for rack to dry i popped down to burton power and picked up some heat matting so can line the bulkhead transmission tunnel as the original heat proofing had perished over time so removed all that ready for the new stuff.
All the old perished heat proofing removed
Hour later all fitted on was easier to apply then what i was expecting.
Once engines in and bay is all complete alot of this wont be seen but it looks alot more fresher now that the heat proofing and replacement bulkhead panel is all in now.
Old May 5, 2013 | 10:18 PM
kosienutter
Great progess
Old May 20, 2013 | 10:51 PM
RSCossieGaz
Abit more progress on the saph front crossmember and rack now bolted back into postion.
Got the front springs clamped (cheers Tony!) onto the koni's i bought off karl 3dr
Then fitted the koni's onto the front hubs before fitting the front suspension back onto the car
Thats now the front all fitted up just need to replace one of the tie rods as one of the threads is damaged so may well just buy a new pair now.
Old May 24, 2013 | 10:01 PM
Tony Rs's Avatar
Tony Rs
No probs Gaz good update chap
Old May 24, 2013 | 10:19 PM
RSCossieGaz
will be cracking on with it again one day over the weekend got hold of a pair of tie rod ends and handbrake cable no so if your a a loose end....
Old May 26, 2013 | 09:32 PM
Hows it coming on matey.
Old Jun 2, 2013 | 09:32 PM
RSCossieGaz
Picked up some alloys for the car thought i would go for something different that i havent had before there 17' speedline Turini's these will be refurbed later on before cars done.
Not much done on the car this week but got it out and swapped ends so can crack on with sorting out the rear end.
Desided to go completely 2wd rear end on the car now so have started collecting the bits i need got a 7.5 diff and picked up 2wd rear beam and arms today at santa pod,just need to source 2wd driveshafts now.
Old Jun 3, 2013 | 10:46 PM
RSLUBBY's Avatar
RSLUBBY
Nice to see some progress mate don't look far off
Old Jun 4, 2013 | 09:44 AM
RSCossieGaz
Still along way to go yet but getting there slowly hopefully during this month i can get the back end sorted.
Old Jul 7, 2013 | 02:08 PM
RSCossieGaz
The rear end has all been removed from the car now and at classic ford show i picked up a 2wd rear beam complete along with another set of trailing arms- these being in better condition then what i took off the car.
2wd rear beam and arms in need of the refurbing.The beam is at working being sanded down and tided up etc while thats being done ive started on the rear trailing arms.
Rear trailing arms been wire brushed cleaned etc of loose rust etc ready for a coat of paint
I desided to spray the arms in hammerite silver-will need afew coats once dry,also will be replacing the bushes for some poly bushed ones before it goes back under car.
Old Jul 7, 2013 | 03:54 PM
Cool progress matey. Are 2wd rear arms not the same as 4x4 arms????I always thought they were the same.I know the beam is different.
Old Jul 7, 2013 | 04:39 PM
RSCossieGaz
Yeah there the same Glenn - they came with the 2wd rear beam
Old Jul 7, 2013 | 04:40 PM
cossie daz's Avatar
cossie daz
Looks a good car there
Old Jul 7, 2013 | 07:22 PM
fezzajsy's Avatar
fezzajsy
looking good mate
Old Jul 7, 2013 | 08:19 PM
Cilly-jey's Avatar
Cilly-jey
Cracking job friend
Old Jul 8, 2013 | 02:10 AM
kosienutter
Cracking progress bud. very nice finishes
Old Jul 8, 2013 | 05:26 AM
MARCOSWORTH's Avatar
MARCOSWORTH
That's a nice project
Old Jul 8, 2013 | 08:20 PM
RSCossieGaz
Cheers for the comments lads
Popped to the garage after work to give the top half of the trailing arms a coat of paint.
Old Jul 8, 2013 | 10:08 PM
ram's Avatar
ram
Has a large member
good effort
Old Aug 12, 2013 | 06:46 PM
RSCossieGaz
Ok bit of an update - along with the rear axle removed also now fuel craddle and fuel tank have been removed so the complete rear end is stripped now!
First of all i wire brushed drilled all of the lose rust and shit off from the underside of the spare wheel well and bootfloor above where the tank sits
This is by no means going to be a concourse finish show car but just a good tidy up and smarten up the rear end.
Now with most of the lose rust etc removed i gave the rear underside its 1st coat of hamerite black under body seal.
I left that for afew days to dry and then tacked the underside above where beam sits and painted that too along with giving the wheel well and boot floor a 2nd coat of paint.
Left that now to dry and in few days will give beam section its 2nd coat and then carry on further back so in the end whole underside will be painted and undersealed.
