ST170 Rattly Cat
Old Apr 25, 2013 | 04:09 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default ST170 Rattly Cat
So had the noise checked on my car today, and what was thought to be a lose exhaust guard turned out to be a rattly cat.
So what are my options (the car past it's MOT last week).
Old Apr 25, 2013 | 04:14 PM
RichieST's Avatar
RichieST
either new cat or a decat. I'd personally put a new cat on it, not worth the risk of running a decat. Pretty soon the cat brick will start breaking up and will block the exhaust.
Old Apr 25, 2013 | 04:26 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
O.K cheers Richie I've heard bad things about decats on a 170.
Old May 11, 2013 | 12:42 AM
Toni-Lee's Avatar
Toni-Lee
I had the same problem on mine a few weeks ago, check that there r 2 brackets holding ur cat in place as this causes the cat 2 rattle and eventually break. Apparently its a common fault on ST170's! If it passed its MOT then the emissions must b ok which would suggest the cat was / is still working.
Old May 11, 2013 | 03:58 AM
louis_2012's Avatar
louis_2012
I took my cat off my Focus and smashed the brick out the side of it, just put a bar down the engine end of it and give it a few whacks with the hammer and then shake the pieces out, made it sound a bit raspy but was only a cheap car.
Old May 11, 2013 | 09:51 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
That's an idea, I will take a look on the ramp on Monday, cheers.
Old May 11, 2013 | 10:02 AM
Can you not decat it.Then do the mod to fool the ecu in thinking the cat is still there.
Old May 11, 2013 | 10:58 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thank Glen, I will take a look on Google
Old May 11, 2013 | 12:00 PM
RichieST's Avatar
RichieST
Decats are good until mot time where you will need a cat. Or if you get pulled over for a vosa roadside check, where you will need plenty of lube lol
Old May 11, 2013 | 01:32 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Do you think the fact mine is rattly it would effect the overall performance of the car, as the flat spot around 2-3000rpm seems to be more apparent now, or is this due to the fact it's an ST170, and let's face it, they aren't really quick to begin with ?
Would a sports cat actually offer anything over a stock one other than noise ? or are there really any more gains to be found in a cat back system ?
Old May 11, 2013 | 01:57 PM
RichieST's Avatar
RichieST
The standard system on an st170 is actually pretty good, you might gain 2-3bhp from a sports cat but then again it'll be much more expensive than a standard one.
I would've thought if the cat brick is clogging the exhaust then you would notice a lack in power right through the rev range. You could always smash the brick out and see what happens. The EML will eventually come on though as the 2nd sensor will soon realise the cat isn't working as it should.
Old May 11, 2013 | 03:36 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Cheers Richie, I will explore some options at work on Monday morning
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
