Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Rear spring replacement
Old Apr 25, 2013 | 10:25 AM
neil andeRSon's Avatar
neil andeRSon
Default Rear spring replacement
How easy/hard is it to replace the rear springs on a T plate focus saloon?
Old Apr 25, 2013 | 02:13 PM
escortmk3rwd's Avatar
escortmk3rwd
doddle slacken shock bolts drops down far enough
Old Apr 26, 2013 | 01:06 PM
Thrustyjust's Avatar
Thrustyjust
Did a full eibach spring change on my ST in uder 3 hrs and the front struts took most of the time. As said, just undo the lower shock bolt, the arm will drop down and leave the spring loose to remove.
3drRich
Sep 13, 2015 07:32 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
