Bams Grey RS
Old Apr 19, 2013 | 10:48 PM
bamcossi's Avatar
bamcossi
Default Bams Grey RS
before i bought this car it looked like this
and then Liam the last owner stripped it and made it look like this
so i popped down to sussex with my luton van and swapped the RS for a crisp £50 note
feb 2012 the resto started
Old Apr 19, 2013 | 10:51 PM
bamcossi's Avatar
bamcossi
sorry about the double pic , this pic should have been there
Old Apr 19, 2013 | 11:10 PM
We_The_People's Avatar
We_The_People
10 Year Member
Looks like a good project
Old Apr 19, 2013 | 11:47 PM
cossiestu's Avatar
cossiestu
Surprised it fitted in the back of a luton!?
Old Apr 20, 2013 | 05:50 AM
dazrsturbo's Avatar
dazrsturbo
50 quid!!!! deal!!!
Old Apr 20, 2013 | 05:59 AM
liam-rst's Avatar
liam-rst
shit happens
I'll give you £100 for it lol, seriously good luck with it .mate
Old Apr 20, 2013 | 08:50 AM
1905Jeremy's Avatar
1905Jeremy
Sweet looking 88 spec before. Hope you keep it that way and keep the updates going. Just started my resto thread on here as GGR S2 so bound to be asking lots of questions.
Old Apr 20, 2013 | 08:54 PM
I hope you restore it back to its former glory.
Old Apr 21, 2013 | 11:40 AM
Louis_RST's Avatar
Louis_RST
Great project!
Old Apr 21, 2013 | 03:52 PM
RSmark84's Avatar
RSmark84
Lads the car looks nothing like before, and will look even better than ever once its finished. You should really check out the resto on the RSOC forum.
http://www.rsownersclub.co.uk/rsocbb...d.php?t=394605
Anyway i'll let bam continue from here.
Old Apr 22, 2013 | 06:52 PM
bamcossi's Avatar
bamcossi
ha ha cheers for that Mark , I will add a bit more to this thread now i have 10 minutes spare , it fitted in the back of the Luton lovely
cut a bit of the rot out here
made a new bit to go in
new inner arch in place , the silver spray is weld through primer
Old Apr 22, 2013 | 06:58 PM
bamcossi's Avatar
bamcossi
outer arch tacked in place
this bit was rotten so i made a new one
and welded in
lower quarter tacked in place
all welded up
some one had done a poor job of the tray in the past
so i cut the lot out
new one welded in
Old Apr 22, 2013 | 07:40 PM
RS##BAM's Avatar
RS##BAM
ok next bit was the fuse box side
cut the rust out
made a new plate
and welded in
Old Apr 22, 2013 | 07:48 PM
RS##BAM's Avatar
RS##BAM
another hole in the floor
Old Apr 22, 2013 | 07:53 PM
RS##BAM's Avatar
RS##BAM
welded in
drivers side arch
Old Apr 22, 2013 | 08:11 PM
RS##BAM's Avatar
RS##BAM
all cut out , i left the cillin for now to use as a datum
i bought a second car for parts , i cut out the first part i needed
rotten window frame cut out
and welded in
new inner rear arch in place
drivers inner lower quarter i made
drivers side all welded up
sun roof tray that is very rotten
i removed the whole tray and set about trying to find a good replacement
after lots of searching and every roof i looked at being rusty i decided to go for a sunroof delete option
Old Apr 22, 2013 | 08:15 PM
RSmark84's Avatar
RSmark84
Jesus christ, that was rotten to fuck. It looked so good when Liam had it at the shows, just goes to show what lies beneath. To be honest i'd of chucked the towel in if i owned that.
Still it looks pukka nowadays.
Old Apr 22, 2013 | 08:24 PM
RS##BAM's Avatar
RS##BAM
a used none sunroof skin thanks to Twins
i left the crossmembers on the skin as this would half the amount of welding on the roof
clamped on in place
did a bit of prep inbetween looking for a roof
also stripped some more parts from the red car for powder coating
Old Apr 22, 2013 | 08:35 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Nice project mate! Gonna be a cracker!
Old Apr 22, 2013 | 08:41 PM
RS##BAM's Avatar
RS##BAM
with all the welding done i started on the underside
sand blasted the underside
it found a few more bits of welding but in all was pretty good
gave the underside a good coat of 2k epoxy primer , this is used to paint shipping containers so its good stuff
these parts you can see that i did not prime are poor previous chassis repairs that i will rework
Old Apr 22, 2013 | 08:52 PM
escortmk3rwd's Avatar
escortmk3rwd
great job coming on well
Old Apr 22, 2013 | 08:53 PM
RS##BAM's Avatar
RS##BAM
found a pic of the roof welded on
i prepped and painted the underside ,engine bay and inside
i used 3m stone gaurd on the underside before painting
the sharpe eyed ones will have noticed its not mercury grey , its a Ral colour none metallic grey
the shockers needed a fettle so i prepped and painted these a lighter grey and powder coated the springs black
and after the work
i started to fit a few refurbed parts that i removed from the red car
Old Apr 22, 2013 | 09:02 PM
AJC's Avatar
AJC
Great progress
Old Apr 22, 2013 | 09:27 PM
RS##BAM's Avatar
RS##BAM
thanks lads ,photobucket is acting up for me big time for some reason so struggling with the pics
Old Apr 22, 2013 | 09:35 PM
RS##BAM's Avatar
RS##BAM
the engine from the red car was stripped , head rebuilt with new cam tappets , valves ect ect then built back up with new gaskets and bolts
then on to the gearbox
before work started
and after a good clean . a coat of etch primer then stratos silver with 2k clearcoat
dropped the engine and box in the car with all new engine mounts and powder coated gearbox cradle
Old Apr 22, 2013 | 09:52 PM
RS##BAM's Avatar
RS##BAM
im fitting st170 discs and calipers to the front so i had to drill out the mounting holes from 10mm to 12mm
there nice and tight when fitted , just need to remove and paint the calipers and spacers now
a bit of filler to level things out
Old Apr 22, 2013 | 11:24 PM
bamcossi's Avatar
bamcossi
prepped the wheels for paint
and painted them the same colour as the boot decal
Old Apr 23, 2013 | 05:52 AM
Turbo Al's Avatar
Turbo Al
great project this one
Old Apr 23, 2013 | 09:33 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I am really enjoying reading this well done.
Old Apr 23, 2013 | 05:48 PM
escortmk3rwd
my mk3 escort is cedar green looks same colour
Old Apr 23, 2013 | 09:19 PM
Louis_RST's Avatar
Louis_RST
Great progress, Im impressed with the roof job.
Old Apr 23, 2013 | 09:57 PM
bamcossi's Avatar
bamcossi
cheers guys , a bit of an update of what ive done tonight
rear brakes fitted
stud conversion done but im changing to shorter studs as these are a bit long
hanbrake cable fastned in
Old Apr 24, 2013 | 02:50 AM
Beach's Avatar
Beach
Nice looking car!!!! Shell looks pretty good underneath
Proper gutted its the same RAL colour as mine i think looks identical noooooooo
Not a million miles away in Mansfield too
Old Apr 24, 2013 | 02:59 AM
Beach's Avatar
Beach
Also mate ive got a load of parts if you need anything give us a shout
Old Apr 24, 2013 | 07:42 AM
bamcossi's Avatar
bamcossi
ha ha cheers , what RAL colour is yours ?
Old Apr 24, 2013 | 07:19 PM
FordRSmania's Avatar
FordRSmania
FordRSmania
very nice project keep on the good work
Old Apr 24, 2013 | 10:07 PM
Beach's Avatar
Beach
7031 Blue Grau or something like that it looks identical last night on me night shift i had to keep checking as it thought it was my car on the under bonnet shots pmsl
Looks amazing when its all done pal i love thwe colour gets so m uch attention mine was painted 5 years ago now just obly made itn out for one or two shows before the BC gave in. Shes having a full cage and new engine and box at NMS just need to make a start.
Cant wait, good look with the project
Old Apr 24, 2013 | 10:23 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
liking the look of this good work mate
Old Apr 29, 2013 | 09:05 PM
RS##BAM's Avatar
RS##BAM
thanks for the nice comments lads , Beach im so frickin glad yours is a differant RAL colour to mine mines 7015
i got some primer on it yesterday
and started blocking the primer down
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
neilrev
Sep 24, 2015 04:31 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
