Gear linkage rebuild, springs/blocks
Old Apr 19, 2013 | 03:01 PM
drl's Avatar
drl
Default Gear linkage rebuild, springs/blocks
Hi I've got quite a bit of side to side play in my gear linkage from the selector housing not from the UJ. Will new springs and blocks improve this? Can I replace them without removing linkage from car I.e. remove torx screws, remove four bolts of selector housing, drop housing, replace blocks/springs and then refit housing?
Thanks
Old Apr 19, 2013 | 04:10 PM
RSmark84's Avatar
RSmark84
Why not buy a new one? someone on RSOC did the other month or late last year.
Old Apr 19, 2013 | 07:14 PM
rsmark86's Avatar
rsmark86
The one for sale in my breaking thread is very good
Old Apr 20, 2013 | 04:57 PM
drl's Avatar
drl
Didn't know they were still available from fords?! .... The springs and blocks are Ł12 of the bay so cheaper than another linkage.
Does anyone know if I can change the springs and blocks with linkage still attached to car?
Old Apr 20, 2013 | 05:05 PM
swiftyrs's Avatar
swiftyrs
S1 or s2 rst linkage ??
S1 the springs r smaller diametre .blocks r the same .
Gear linkage off imo ,eassier 2 do that way
stick a puma linkage on less throw , quicker gear change ,
Old Apr 20, 2013 | 07:24 PM
drl's Avatar
drl
S2 linkage ... It may well be easier to do off the car but can't I just do what i described in my first post?
Old Apr 21, 2013 | 02:43 AM
simonmcf's Avatar
simonmcf
Use puma gear linkage?
Old Apr 21, 2013 | 03:20 AM
Chopshop85's Avatar
Chopshop85
I would just go the puma linkage route.
Old Apr 21, 2013 | 08:12 AM
swiftyrs's Avatar
swiftyrs
Its an up grade si
Bin standard rst linkage , put a puma 1 on , basically similar 2 puttin a b un m quick shift on ur rs , also reduces vibration , since puma lingage has a rubber mount at gear stick end , u just need 2 drill 2 holes 2 mount it in position .
Only draw back is there will b now gate 2 stop u sellecting reverse whilst goin from 3rd 2 4 rth , but i personally aint ad this 2 happen yet ..lol , is a good upgrade for the price though , Ł25 from a scrappy ... Can put pics up if u like wen on car ,2 c fittment ???
Drl......... I suppose u could do it on car , springs r easy enough 2 change as u just un do the torx screws on side of case in , its the blocks u may av probs with as they can b fiddly as ull need 2 do the through top , it really is just as easy 2 take linkage off , select 2nd gear so gear box rod is pushed into box un un do off gear box un drop whole thing down un off ....
Old Apr 22, 2013 | 05:52 AM
Fordmad!'s Avatar
Fordmad!
Does the puma linkage fit a mk4 xr3i?
Old Apr 22, 2013 | 07:44 AM
haz87's Avatar
haz87
Yes it does
Old Apr 22, 2013 | 11:43 AM
Rogeyboy's Avatar
Rogeyboy
The puma linkage doesnt "self centre" in neutral like the Mk4 linkage does...
Old Apr 22, 2013 | 04:56 PM
haz87's Avatar
haz87
Not hard to sort tho
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
The Youth.
Sep 30, 2015 09:59 PM
