Cossie ECU questions.....L8 or P8 ?????????
Old Mar 15, 2005 | 11:42 AM
Disabled Account's Avatar
Disabled Account
Default Cossie ECU questions.....L8 or P8 ?????????
I'm confused by L1 L2 L4 L6 L8 P8 blah.......
Some questions for those in the know.........NOT a quizz.........lol
a. What is the standard ECU that's fitted to late Saph Cossie's (92/93 models)
b. What is the standard ECU that's fitted to Big Turbo Escort Cossie (92/93 models)
c. Where can I buy a MINT or NEW engine wiring loom to suit either of the above....i.e. complete loom that plugs into the ECU and into all engine sensors.
d. As "c" above, would I be better off getting a custom loom made up by Dingy?????
TIA
Old Mar 15, 2005 | 11:44 AM
SapphyMike's Avatar
SapphyMike
Default Re: Cossie ECU questions.............
Level 8
P8
Dunno
Get one from Dingy
TIA
Old Mar 15, 2005 | 11:45 AM
Billabong's Avatar
Billabong
TIA
a. L8 (with lambda control software)
b. P8 (early ones *might* have a CO pot )
c. Pectel / Ahmed / Mike R
d. Possibly yes, speak to him - peeps seem happy with his looms.
manoj's Avatar
manoj
TIA
L8 = Saph 4x4 Cossie
P8 = EsCos - Big Turbo.
Old Mar 15, 2005 | 02:05 PM
Disabled Account
OK, thanks for answers so far
Next, choosing the best one of these two:
L8 ?
P8 ?
Which would be best for a live mapped 330 BHP engine on greens/T34 turbo, to be used for fast road/track days WITH NICE LOW (MOT passable) emisions????
And finaly, which would be best for a live mapped 500 BHP engine on 750 or 1000 CC (MSD) injectors/T4 turbo, to be used for fast road/track days WITH NICE LOW (MOT passable) emisions????
TIA........
Old Mar 15, 2005 | 02:09 PM
SPADGE's Avatar
SPADGE
I would only use the P8 if i was going to run anti-lag and for no other reason Doug!
Old Mar 15, 2005 | 02:11 PM
DazC's Avatar
DazC
L8 will control 790cc injectors. We are unsure how P8 will handle them but we will find out around the end of April.
Old Mar 15, 2005 | 02:12 PM
Disabled Account
Thanks Spadge...........can you PM me prices for P8 and L8 please.......even if you hav'nt got either at the moment, then what sort of prices I should expect to pay?????
Old Mar 15, 2005 | 02:14 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Doug, speak with Ryan, he will do you an AWESOME brand new loom for a very reasonable price, all new wires, connectors, pins etc.....they are a work of art (And cheaper than Pectel and other manufacturers looms )
Old Mar 15, 2005 | 02:20 PM
GARETH T's Avatar
GARETH T
P8 and get stu too map it,,,,,
what about an s8?
Old Mar 15, 2005 | 02:36 PM
Disabled Account
Originally Posted by GARETH T
P8 and get Stu too map it.........what about an s8?
Gareth, I need TWO ecu's and I am asuming that L8 or P8 are both as cheap as chips..........
Old Mar 15, 2005 | 02:37 PM
GARETH T's Avatar
GARETH T
sorry mate, i should of read the question
Old Mar 15, 2005 | 02:38 PM
DazC's Avatar
DazC
P8 will vary from Ł350 to Ł500+ depending.
L8 as a general rule are around Ł200.
Old Mar 15, 2005 | 02:51 PM
Disabled Account
Daz/Gareth thanks for replies...........
So what (apart from anti-lag) does a P8 offer that an L8 cant/wont do?????
I.E. what are the disadvantages of using the much cheaper L8 when compared to P8 ?????
Old Mar 15, 2005 | 03:13 PM
foreigneRS's Avatar
foreigneRS
Testing the future
why, can you drive 2 cars at the same time?
Old Mar 15, 2005 | 03:19 PM
Disabled Account
Old Mar 15, 2005 | 03:20 PM
CraigN's Avatar
CraigN
you want a nice 2wd saph ecu L6 like i have
runs the engine dont it
Old Mar 15, 2005 | 03:24 PM
GARETH T's Avatar
GARETH T
p8 has more memory (which i wouldnt mind a bit more of )
p8 runs closed loop boost control (well i think so)
p8 can run coil packs with a software change!
thinking about it,, either wil suit you,, i wouldnt run pectel software though amd get closed loop lambda control for the road car
also if i was paying for a live map, i would do so on grays
Old Mar 15, 2005 | 03:27 PM
Disabled Account
Gareth, so I cant use coil packs or closed loop lambda on an L8 then ?????
Or light blues ??????
Old Mar 15, 2005 | 03:29 PM
GARETH T's Avatar
GARETH T
yes you can,, but to run coil packs on a l8,, you need a secs hareware upgrade
grays are cheaper
Old Mar 15, 2005 | 05:14 PM
markk's Avatar
markk
you have to be using as many of the functions on P8 as we know about to make it worth the while having over L8, but i t does have alot of functions that L8 doesnt have as std that are very advantageous to your low emisions that your are very keen on ( )
the key to either is someone who really can do you a live map , and it really must be live , useing the biggest injector combo will run beautifully all the way through the rev range
Old Mar 15, 2005 | 05:53 PM
jon@work's Avatar
jon@work
So how do you tell the difference between a L8 and a P8 ? (part numbers on the lid, or another way ?)
Old Mar 15, 2005 | 06:31 PM
ImaRacing 700's Avatar
ImaRacing 700
Doug get an S8
I have an L8 for sale in parts
GARETH T's Avatar
GARETH T
jon@work, the l8 has a co screw,, the p8 wont (most havent anyway )
Old Mar 15, 2005 | 06:38 PM
jon@work's Avatar
jon@work
thanks Gareth
Old Mar 15, 2005 | 06:46 PM
Ian M's Avatar
Ian M
mines on a L8, greys mapped by stu and runs at 0.6% co.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
