Quick car electrics question,
Old Mar 15, 2005 | 07:48 AM
Gra's Avatar
Gra
Default Quick car electrics question,
I have a charger for my XDA with power for my GPS reciever which plugs in to my ciggie lighter, can i cut the wires and wire it up to the power from the steroe or fag lighter? would it be ok or would i need relays etc?
Old Mar 15, 2005 | 08:32 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no problem gra, the current draw from those 2 items is tiny. no need for any relays or anything. you might want to put low ampaerage fuses in line to protect those devices though, as the ciggie lighter and stereo will be quite high.
Old Mar 15, 2005 | 08:37 AM
3drstretch's Avatar
3drstretch
You cant just cut the wires and plug them straight to the power from the ciggie lighter as PROBABLY in the ciggie lighter end there will be resistors to bring the voltage down so break open the plug then seperate the plug from wires then you should be fine.
Old Mar 15, 2005 | 08:43 AM
Gra's Avatar
Gra
cheers
Old Mar 15, 2005 | 09:17 AM
EssexBoyRacer's Avatar
EssexBoyRacer
There's no resisters in the Cig lighter that reduces voltage. Its 12v all the way.
As per foreign RS though, add an inline fuse to the supplies for the extra devices as the only fuse for the cig lighter is fairly high (sommit like 25 amps)
Old Mar 15, 2005 | 09:25 AM
St3V3_C's Avatar
St3V3_C
XDAII power supply is 5V - I'm 99% sure XDA is the same, so DO NOT connect direct without checking - it may be OK, but check it.
Go ahead and cut the wires, plug in the ciggie lighter bit and measure the voltage coming out.
Old Mar 15, 2005 | 09:30 AM
Gra's Avatar
Gra
meant to say its an XDA2
Old Mar 15, 2005 | 09:33 AM
St3V3_C's Avatar
St3V3_C
Well, definately measure the voltage then.
Old Mar 15, 2005 | 09:35 AM
Gra's Avatar
Gra
er hows that done? got a multimeter but sod all instructions whats shouldi set it to?
Old Mar 15, 2005 | 09:38 AM
EssexBoyRacer
does the XDA2 not have any indication on it what the input voltage might be?
Would most likely have it printed on the serial number label or somewhere around where the power supply plugs into the unit.
Alternatively, the output voltage from an AC adaptor will tell you as well.
Old Mar 15, 2005 | 09:49 AM
St3V3_C's Avatar
St3V3_C
That's what I have infront of me, and it says 5V
To use the voltmeter set it to volts, up to a maximum that is above 14V and plug the leads in. If you have sockets to choose from, use the black one - might be labelled 0V, -ve, com etc. and the other one into something that says V, NOT A
To check you have it right, put it onto the battery and hope you see 12V ish.
Old Mar 15, 2005 | 09:56 AM
EssexBoyRacer
U'd need a resistor inline then that brings the 12v supply from the cig lighter down to 5v before it supplies the XDA2. Easy enough!
Old Mar 15, 2005 | 09:58 AM
St3V3_C's Avatar
St3V3_C
I will be hugely surprised if it's a resistor and not a voltage regulator/zener. With the resistor you will have a different voltage depending on the load (state of battery, on or off the phone). Thats a bad thing.
Old Mar 15, 2005 | 10:11 AM
EssexBoyRacer
I guess u'd have to break down the cig lighter plug that comes with the XDA2 to tell whether that uses a regulator or just a resistor, but u could just use a cig socket from maplins and wire that in behind the dash. So u've effectively got a hidden cig socket dedicated to the XDA2.
Old Mar 15, 2005 | 10:29 AM
St3V3_C's Avatar
St3V3_C
That will be the best bet
http://www.maplin.co.uk/Module.aspx?...ldID=&doy=15m3
If that link works
Old Mar 15, 2005 | 10:31 AM
EssexBoyRacer
thats it.
Old Mar 15, 2005 | 11:17 AM
Gra's Avatar
Gra
super cool, but getting complicated
Old Mar 15, 2005 | 11:21 AM
EssexBoyRacer
Gra, its dead easy this way. you tap into the cig lighter feeds and solder in that extra cig socket. Then just plug u're XDA2 cig plug into that behind the dash.
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
