Clio 172 Cup Trackcar & Trailer
I have decided to sell my 2003 (53plate) Clio Cup track car, the spec is below. If you wanted to make it a road car again it would cost next to nothing to it as everything. It would fly through an mot i'm sure. HPI clear.
It's in great condition as it's only covered 57k with full service history, mostly from a main dealer.
Mocal oil cooler
Bilstein Coilovers with H&R springs
Ktec KTR top mounts
Air filter, the make model escapes me but it wasn't a cheap thing
Eibach camber bolts
FK Hub centric spacers
Brembo HC discs front & rear
DS2500 pads on the front, Brembo on the rear
Ktec supersport exhaust with ktec dcat
Re-programmed ECU, proper job
Uprated exhaust mount
Motorsport 15" 1.2 pro alloys
Federal 595 tyres
Ktec solid engine mounts
Ktec gearbox mount
Plexi replacement race glass in driver/passenger doors
Rear roll cage
Rear strut brace
Omp suede steering wheel
Magnecor leads
Corbeau Evo race seat
5 point harness
The trailer is in superb condition.
I'm sure i have missed loads out however i think it gives a good out line on what has been done.
I bought the car off a mature owner & fitted all of the above, i have only managed to do 2 trackdays sadly so everything is still in pretty much new condition. I have spent a lot of cash but enjoyed the process of building it to a high level.
I have pictures but they won't upload so if your interested ill email them to you.
£3500 ovno for the car & trailer.
Mark 07771-985174.
Mocal oil cooler
Ktec KTR top mounts
Eibach camber bolts
Federal 595 tyres
Ktec gearbox mount
Rear roll cage
Rear strut brace
Magnecor leads
5 point harness
Mark 07771-985174.
I dont want to split really, gaaables is interested in the trailer i'm sure if interested you may be able to put your heads together. Sorry i'm just after one sale.
I haven't got any spares, everythings on the car
. If need be i can take some of the inside & get them to you, i store the car 2 miles away from my house due to room so i need to pop up there in the next couple days. Its secure entry that closes at 6pm so its a bit tricky.
Fudgey
Sep 17, 2015 01:06 PM
