2005 ST220 replacing rear crank seal
Old Mar 27, 2013 | 02:08 PM
clarky's Avatar
clarky
Default 2005 ST220 replacing rear crank seal
I've had quite a bad oil leak between the engine and gearbox. Thought it was the sump gasket so changed that but it's still leaking.
I've been told it's probably the rear crank oil seal so I'm going to try and change it.
Do I have to remove the subframe completely or can I just drop it down on the gearbox side ?
If I can drop it down on the one side, do I need to undo the bolts holding the steering rack to the subframe or can they be left alone ?
malkiemac3579
Jul 14, 2017 12:10 PM
YODI
Aug 30, 2015 01:12 PM
st220kyle
16
Aug 14, 2015 06:13 AM
pegaz
11
Aug 9, 2015 06:40 PM
lockie
Jul 31, 2015 10:03 PM
