Rear washer problem
Old Mar 25, 2013 | 03:35 PM
Danny Hodge's Avatar
Danny Hodge
Default Rear washer problem
Hi all, am new to this forum looking for help with my rear washer not working but front work fine!! Can hear pump but no spray or leaks????
Thanks
Old Mar 25, 2013 | 03:40 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
What car? Could be a bunged up jet (clear with a pin) or the hose has popped off the squirter. Dismantle, replace, fix. Job done.
Old Mar 25, 2013 | 03:47 PM
Danny Hodge
Thanks for reply its a mondeo tdci and i have had the nozzle off and cleaned it but still nothing just a bit water out off the front when a want the back,, if it had come apart some where then a would have a leak but theres no leak??
Old Mar 25, 2013 | 04:44 PM
Paul_RS's Avatar
Paul_RS
Hose comes off behind the C pillar, pull the plastic trim off and check in there.
Old Mar 25, 2013 | 05:14 PM
Danny Hodge
Would there not be a leak if it was that??
Old Mar 25, 2013 | 05:42 PM
davy 6457's Avatar
davy 6457
it will but if you hold the button on long enough you'll prob see it starting to leak as paul says though its more than likely behind the drivers side c panel trim. 5 min fix at tops
Old Mar 25, 2013 | 06:23 PM
wulliegunn's Avatar
wulliegunn
I had same problem few weeks back.I heard the scoosh sound but no water. Took off trim next to rear right(head height),and I had a lovely stream of blue pissin down over the air bag gadget.
Old Mar 25, 2013 | 07:42 PM
Danny Hodge
Thanks for the help will take the trim off 2morro have a look, a took the brake light off and its not leaking there
Old Mar 26, 2013 | 11:28 AM
DanW@FastFord
Spelling Club King!
You need to start at the back and work your way down the car until you find where it's become disconnected. It could have come adrift somewhere where the water can't be seen. It will be leaking somewhere.
Old Mar 26, 2013 | 12:06 PM
Danny Hodge
Going to have a quick look now a thought there was only 3 joins, 1 at the nozzile which is ok cause had that out, 1 in the panel behind the driver and 1 on the pump? No water comes out under the car!!!
Old Mar 26, 2013 | 12:55 PM
Danny Hodge
Thanks for help every1 its now fixed 😃😃😃😃 it was the pipe behind c pillar
Old Mar 26, 2013 | 12:57 PM
Danny Hodge
*panel
skypeller
Sep 19, 2015 09:58 PM
Ade
Aug 31, 2015 06:41 PM
borboyous
Aug 22, 2015 11:17 AM
155lee
Aug 14, 2015 11:21 AM
Gadget
Aug 13, 2015 08:19 PM
