Lost Ford keys, now what ?
Long story short ........
My 2012 Ford Fiesta S keys have been lost whilst at the dealers
If new keys supplied (by the dealers) are programmed to fit and work will my old "lost" keys still work if then found, or do the become redundant ?
Obviously I want to know purely incase someone has ideas for my car
They should remove all old keys from the system so they should not disengage the immobiliser, however they will probabaly still work in the door locks, which I would want changing too!
Ok cheers
Good point, they "could" still get into it as the old key still fits the old locks
I assume the old keys wouldn't bypass its alarm tho if the lock is manually operated?
don't know about fords, but i do know that merc's programming removes the old keys from the system and only programs the "new" keys to the vehicle
i'd want the locks changed as well as even if they did unprogram the old keys out, theres nothing to stop a scallywag from finding them with your reg tag on them and pushing your motor away while you are sleeping
rst-s1
Aug 23, 2015 07:56 AM
Daisychain
Aug 22, 2015 08:12 PM
borboyous
Aug 22, 2015 11:17 AM
