Need help with oil jet!!!
Old Mar 17, 2013 | 07:54 AM
Jasu's Avatar
Jasu
Exclamation Need help with oil jet!!!
Hi guys.
I need help to ID my oil jet.
Recognizes someone?
Old Mar 17, 2013 | 08:43 AM
Mark Shead's Avatar
Mark Shead
Julian Godfrey sells them.
Mark
Old Mar 17, 2013 | 08:48 AM
Jasu's Avatar
Jasu
Mark
Hi Mark and THANKS.
Are you sure that those what Julian sells don't have flat surface on bottom?
http://www.racetuners.com/shop/ford-...s-4-per-engine
Old Mar 17, 2013 | 09:08 AM
Mark Shead's Avatar
Mark Shead
Originally Posted by Jasu
Hi Mark and THANKS.
Will check when I get to work as I have a few sets from him.
Mark
Old Mar 17, 2013 | 09:26 AM
Jasu's Avatar
Jasu
Mark
I appreciate it.
Old Mar 18, 2013 | 07:36 PM
Jasu's Avatar
Jasu
Hi Mark.
Did you remember to check?
Old Mar 18, 2013 | 07:42 PM
Mark Shead's Avatar
Mark Shead
Hi Mark.
Sorry forgot, Looking at them again they loook like the ones but they have been modifede to have more clearance as with a stroker crank with 8 counter weights are very tight to them.
Mark
Old Mar 18, 2013 | 07:46 PM
Rsmat's Avatar
Rsmat
How and what oil jets can I fit in my Rs500 block ?
Old Mar 18, 2013 | 07:48 PM
Mark Shead's Avatar
Mark Shead
The block needs to be modded and I would recomend you use the JG ones.
Mark
Old Mar 18, 2013 | 07:57 PM
Rsmat's Avatar
Rsmat
Mark
Thanks Mark... What cost are involved and who does it as a rough guide mate ..and is it something worth while even though I won't be running big power..? ( staying 400 there abouts mate )
Old Mar 18, 2013 | 08:01 PM
Mark Shead's Avatar
Mark Shead
I only tend to bother with the stroker engines.
Mark
Old Mar 18, 2013 | 08:10 PM
wes's Avatar
wes
Hi Mark and THANKS.
The ones Julian sells have a flat bottom (where they go into the block) as per the original EEC-IV oil jet.
Send them an e-mail or call them I'm sure they will be able to help you out
Old Mar 18, 2013 | 08:27 PM
Rsmat's Avatar
Rsmat
Mark
Ah got ya .. Cheers mark
Old Mar 19, 2013 | 04:22 AM
Jasu's Avatar
Jasu
Thank you guys.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
