Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
heater control problem
Old Mar 16, 2013 | 07:27 AM
Daniel-1986's Avatar
Daniel-1986
Default heater control problem
My heater controls have stopped working apart from setting 4 what would it be for all but 1 to stop working, its a mk1 focus
Old Mar 16, 2013 | 07:40 AM
dojj's Avatar
dojj
Resident Wrestling Legend
It'll be the risistor pack being fucked from previous posts about the subject
not sure if its just plug and play or a solder job though so may want to wait for someone who's done the job to explain what's what about the chsnge
Old Mar 17, 2013 | 10:19 AM
Daniel-1986
Need to get it fixed asap, already hate using setting for 4, plus how do I get to the resistor
Old Mar 17, 2013 | 11:33 AM
martysmartie's Avatar
martysmartie
You need to drop the glovebox down and you can then see the resistor pack.
Does your passenger footwell get wet?
Martin
Old Mar 17, 2013 | 12:24 PM
Daniel-1986
Found it, just got 2 from the scrappy, 1 white and 1 blue if there a difference between for Ł5, no footwells are dry. They are a farce to get not a lot of room for a screw driver
Old Mar 17, 2013 | 06:01 PM
Daniel-1986
all fixed now, lucky I got little hands with being a tight space to work with, going to keep the other one I got as a spare incase this one dies on me
Old Mar 25, 2013 | 06:20 PM
Jdevaney89's Avatar
Jdevaney89
When the glovebox is down there is a hole that you can fit a lengthy screndriver down and fortunately the screw seems to stay sat in the pack, i changed this last week, doddle. Changing the water pump, isnt.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Flatlinedan
Sep 18, 2015 12:41 PM
markk
Sep 9, 2015 08:11 AM
routemaster
Sep 7, 2015 05:27 PM
