zetec in a mk4?? carbs or injection??
Old Mar 14, 2013 | 08:38 PM
jamescosworth's Avatar
jamescosworth
Smile zetec in a mk4?? carbs or injection??
just picked up a mk4 bonus to start as a summer project...been looking at engines that dont cost too much as im on a budget. there seems to be plenty of 1.8 silver top zetecs around for not too much money. just looking for some info as to whats needed to drop the engine into my car? is the wiring the hardest part of the conversion?
would it be easyer to go down the carb route? bike carbs and manifold kits dont seem too much money
if i was to go with standard injection what other parts would i need?
any info much appreciated! https://passionford.com/forum/images/icons/icon7.gif
Old Mar 14, 2013 | 08:45 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
I'd say carbs, they sound better, you better throttle response, less to go wrong
Old Mar 14, 2013 | 08:49 PM
jamescosworth
was thinking about going the carb route if i did put the zetec in, nuts and bolts im fine with but when it comes to the wiring im brain dead! whats needed to get the zetec running wiring wise when using carbs? im guessing id only need to get the ignition side of things wired in?
Old Mar 14, 2013 | 08:59 PM
shagster42's Avatar
shagster42
Bike carbs or throttle bodies. I fitted zx6r carbs to my 2.0 blacktop. Cost me Ł280 for carbs, manifold and megajolt.
Old Mar 14, 2013 | 09:02 PM
jamescosworth
how hard was it to set up shagster? where did you but that from mate?
Old Mar 14, 2013 | 09:06 PM
shagster42's Avatar
shagster42
Very easy to setup so far. I bought carbs and megajolt local and manifold i bought from danst on ebay. I've only just got it running but will be going for mapping soon.
Old Mar 14, 2013 | 09:16 PM
jamescosworth
ok cool thanks for the info! you had some bargains then!
Old Mar 14, 2013 | 09:28 PM
oriurbo's Avatar
oriurbo
Carbs all the way
Old Mar 15, 2013 | 08:26 AM
escortmk3rwd's Avatar
escortmk3rwd
bike carbs i used cbr600 use either electric fuel pump and regulater or motorbike fuel pump an esc module and loom off late mk4 early mk5 mk3 fiesta not single point injection blacks live browns earth theres your spark my mate makes inlet on ebay pinkzeteccabby not that much ive build loads now and never went wrong
Old Mar 15, 2013 | 10:14 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
If you do go carbs, get bike carbs, they stay in balance far better than Webers.
Though, for the little extra work, and the far more refinement and better results, just go with ITB's.
For carbs, the easiest and most commonly used is Megajolt ignition, simply need a 36-1 trigger wheel, cam sensor if you want 3D mapping I think, and for carbs, you're better suited with something with at least a 38mm choke, 40 would be better, so GSXR 750 at the smallest.
That's what I can remember from my original plan, but was a while back so don't quote me on details lol.
Old Mar 15, 2013 | 04:36 PM
big.p's Avatar
big.p
Hello sorry to hijack the thread a bit but im currently putting a blacktop into my 90 spec 3i which allready has edis 4 wireing as standard.my question is can i pipe my map into the system to run my advance as its part of the standard engine managemaent
cheers
Old Mar 15, 2013 | 04:40 PM
big.p's Avatar
big.p
Forgot to say its got bike carbs on it
Old Mar 15, 2013 | 05:38 PM
escortmk3rwd
yip ive got my rs1600i rep with 2.0 silvertop in on 45s and megajolt
Old Mar 15, 2013 | 05:39 PM
escortmk3rwd
as for bike carbs ive never had them set up and havent had a problem yet drill jets out 0.5 to 0.7 and use esc module
Old Mar 15, 2013 | 06:34 PM
jamescosworth
thanks for all the help lads!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
