Ford KA Discuss your Ford KA here!
Some one please help ECU problem
Old Mar 12, 2013 | 08:12 PM
fedupwithka's Avatar
fedupwithka
Default Some one please help ECU problem
Please can someone help. See my other posts re ford ka.
Anyway is it possible to get a replacement ecu from a scrapyard and get it fitted, I am at the end of my tether with this. 2002 ford ka duratec 1300.
Im told its possible but would like adviseon what to do otherwise car going to be scrapped Help please.
Old Mar 12, 2013 | 08:30 PM
Piston Broke's Avatar
Piston Broke
Yes mate you need the ECU, key as they have a chip in and the transponder (the bit around the ignition) fella you might as well get the other locks to or build the wards inside the locks on your car to match the new key you get, the key number tells you what wards you need the keys are easy to red like T1234 etc hope that solves it
Old Mar 12, 2013 | 09:08 PM
fedupwithka
Thanks, sorry to be thick but I dont know anything about cars! Im told its very hard to get to the ecu on ford ka and dash needs to be removed? Is this right? By the way Im a girl not a fella
Old Mar 12, 2013 | 10:02 PM
Piston Broke
sorry lady, do you have tools etc as other wise it will be a waste of time telling you lol, how much can you do or you never done anything like this before ?
Old Mar 13, 2013 | 06:37 AM
fedupwithka
Thanks for reply. No never done anything like this before, Have had loads of problems with this car (See other threads) and really cant afford to spend much more on it. I have the choice of getting ecu off and send it back to where it was mended last time, get a scrap ecu and try and get it fitted or scrap the car and get something else cheap untill I can afford something better.
Local garage are telling me you have to remove whole dash to get it out and want to charge £200 for it.
Just dont know what to do and its getting me down. Need a car for work but cant afford much. Any help much appreciated. Thanks
Old Mar 13, 2013 | 06:43 AM
Mr.T's Avatar
Mr.T
Would be crazy to remove the whole dash just to get to the ECU? Don't know anything about the ford ka but it sounds wierd to me. But i geuss you will have to have the key and ECU. As said the key has a transponder in it.
Old Mar 13, 2013 | 06:45 AM
Mr.T's Avatar
Mr.T
Old Mar 13, 2013 | 01:49 PM
martysmartie's Avatar
martysmartie
Have you had the kick trim off in the drivers foot well? The ECU may be there, seems strange it being behind the dash.
Also you don't need the aerial, this merely reads the transponder and is not tied to a specific car.
Martin
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
