Power on the cheap
Old Mar 12, 2013 | 07:56 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Default Power on the cheap
I bought a 1998 fiesta a while back with the 1.3 engine, its bin sitting a while and now I'm contemplating spending some time and money on it, the main question is value for money what is the best option to do: I have so far rebuild the 1.3 and fit bike carbs, or fit a 1.7 puma lump, fit the 2.0 mon zetec engine, build a zvh N/A , or fit a cvh turbo. I'm basically look at time and money as cos its not the greatest shape fiesta I don't to throw money at it but at the same time I'm doing it for ford fair so I want it too look gud too, if any1 can think of a better option it'll be gud to hear it
Old Mar 12, 2013 | 08:02 PM
twoblacklines's Avatar
twoblacklines
If you want power on the cheap, sell it, buy a Volvo 850 T5 or T5-R, and RICO it for 330hp. Should be able to get one for £850 ish.
Old Mar 12, 2013 | 08:53 PM
gjh's Avatar
gjh
The best bet there would be a puma lump, and if the carbs are ok for the size of engine, swap them over, its not too difficult a conversion to do, shouldnt take more than a week end to do it, and there are plenty of puma lumps available. Any pics of the car??
Old Mar 12, 2013 | 09:07 PM
gingerturbo
If I was gunna get a volvo I'd get a 340 or 244
Old Mar 12, 2013 | 09:08 PM
gingerturbo
Yeh most people I've spoke to have said the puma lump, how hard is it getting round the multi plug
Old Mar 14, 2013 | 12:16 PM
sartain87's Avatar
sartain87
You sure about both?
Just a rico map wont get 330bhp, and as for a T5R being £850, i'd check prices
And how reliable will a £850 T5 be?
Old Mar 14, 2013 | 12:54 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
I'm doing a similar thing just now, Puma lump into a base model mk5.
I bought a complete and driving 1700 Puma for £250 so I have everything to do the conversion plus alloys etc, so its a cheap way to more power. There is a comprehensive guide on www.zsoc.co.uk to the conversion and they are all very helpful on there.
The wiring sounds pretty straightforward, as you basically trasfer the engine loom + ECU from Puma straight over to Fiesta and all plugs in as it should
Best of luck whatever you do
Old Mar 14, 2013 | 02:08 PM
m4tt274's Avatar
m4tt274
2.0L zetec. More torque and power than a 1.7 zetec from a puma, cheaper and easier.
you will need a 1.8zetec sump and oil pickup pipe.
With a 4/2/1 and some other little fiddles it should make 150bhp which is more than good enough.
Old Mar 14, 2013 | 02:32 PM
luke19790_3's Avatar
luke19790_3
Don't need to change the sump if you use a blacktop
Old Mar 14, 2013 | 03:28 PM
gjh's Avatar
gjh
I've heard of reliability issue when fitting a 2.0 into them, not sure what these issues were but I was advised of avoiding the 2.0 and going puma due to it. Any idea what these could be?
Old Mar 14, 2013 | 05:45 PM
mothrs2k's Avatar
mothrs2k
The rs2000 lump will fit in a mk4/5 fez pretty easy. Ive seen a few done, 150ishbhp from the off, with the potential for more and cheap enough to buy.
Just get a pre-pats ecu, front mount starter gearbox, and modify the offside engine mount.
Getting around the wiring is easy enough
Old Mar 14, 2013 | 06:24 PM
gingerturbo
I'll have a look around to see what doners are available, both the blacktop and 1.7 zetec s have there issues, I'll start a project thread soon with some pics
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
