RS Turbo CVH EFI Engine
Old Mar 12, 2013 | 07:48 PM
mr_joe0606's Avatar
mr_joe0606
Default RS Turbo CVH EFI Engine
i bought this engine 2 years ago with the intention off converting to efi. its just been sat at the end off my garage not touch since it was delivered.
It's a 50k NA block with the oil return machined, so has not seen any of the temps or abuse a normal RST block would, and of course this has been checked measured and honed.
RST Mahle pistons with brand new Mahle rings on stock rods.
ARP bolts of course.
Ford headgasket and stretch bolts as we know these are good for 350bhp+
Heavy duty ACL bearings/shells throughout.
50k Crank meassured and polished.
Stock EFI head with new stem seals, dizzy blanking plug, cam seal, re-faced, valves re-lapped and fitted with a good used stock cam and lifters so no chance of failure sending metal round your new engine!
Genuine Ford oil pump!
Matt Lewis water pump.
Obviously all gaskets and seals are brand new, it has been built to the highest standard with everything torqued correctly, lubed and bolts locktighted where needed (sump for example).
This engine is good for 240bhp!
Stock rods will take it so long as you dont raise your rev limiter or sit at 6k+ for hours!
This is very important! It has not been run yet!
So Whoever buys it must run it in for the first 1000 miles on good running in oil like Millers, then change for a new filter and oil something like Silkolene Pro S 10/50.
Oh and the cam belt pictured is not new and will need replacing, I fitted it to ensure there is no way of the cam or crank being rotated and pistons hitting valves until I fitted a new one, which of course I'm not doing now.
There is a dent in the corner of the sump, doesnt effect anything but thought i'd mention it, the sump itself is only a few months old but it was on my old engine and gained a dent when taking it out.
The price of the engine is simply the sum of all the parts and machining that I paid so your getting it built for free!
Block & Crank £90
EFI Head £30
Bearings and Rings £160
Gaskets, ARP's, Water Pump £140
Machining £150
Total £570
will take £400 ono
cheers joe
Old Mar 13, 2013 | 06:44 PM
mr_joe0606's Avatar
mr_joe0606
bump
Old Mar 18, 2013 | 05:44 PM
mr_joe0606's Avatar
mr_joe0606
on ebay
http://www.ebay.co.uk/itm/2810774787...84.m1558.l2649
Old Mar 19, 2013 | 08:36 PM
mr_joe0606's Avatar
mr_joe0606
its ending soon
Old Apr 8, 2013 | 03:14 PM
jphopewell's Avatar
jphopewell
Hi,
Have you sold the engine?
Kind regards,
Jonathan
Old Apr 8, 2013 | 08:58 PM
mr_joe0606's Avatar
mr_joe0606
this has now sold
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 15, 2015 10:43 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
