HELP needed with cossie
got the engine back in the cossie but having a few problems
no live to fuel pump but the car runs but shit put a live to the fuel pump and it cuts out ?
when it is running its over fueling other thing is ive broke the map sensor does the map sensor have any thing to do with fueling or is it just manifold pressure
thanx in advance
thanx in advance
Then after that needs a live (which you don't have) so therefore is running until the pressure in the lines drops and starves of fuel......?
the pumps not priming at all but the car will run but badly and yes theres a strong smell of petrol
will try and get a map sensor tomorow and see if i can find the problem with the pump live carnt see the live been down to the map sensor tho
i dont get how it runs with the fuel pump not working
fitted a new genuine map sensor today and its sorted it
i ad a idea it would be this as its the only thing ive broke but wanted to check with you guys before i payed Ł115 for a new one
just the live to the pump to sort out now, was fine before i removed the engine
rewire been done and tryed new relays any how its sorted now left it with my m8 this afternoon duno what hes done but it works said sumet about a bad earth
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
