Focus st engine management light
Old Mar 2, 2013 | 07:27 AM
Richsvt's Avatar
Richsvt
Default Focus st engine management light
I have just fitted a mongoose downpipe and 200 cell sport cat to my focus st and after about 200 miles the engine management light came on ,I thought wit a sport cat it wouldn't do this ,any help would be much appreciated thanks Richard
Old Mar 2, 2013 | 08:00 AM
RichieST's Avatar
RichieST
what fault code are you getting?
Old Mar 2, 2013 | 08:22 AM
Richsvt's Avatar
Richsvt
Thanks for the reply mate ,fault code showing lambda sensor out of threshold ,I think sensor seeing too much flow lol ,going to scc for Revo remap ,so should be ok when remapped ,thanks again Richard
Old Mar 5, 2013 | 11:00 AM
Thrustyjust's Avatar
Thrustyjust
Got a 200 cell on mine and is fine, no codes coming up. Could the lambda be a bit dicky ? I guess you removed it from the old cat, that may have damaged it?
Old Mar 5, 2013 | 12:39 PM
Carlos-Titx's Avatar
Carlos-Titx
That's what code I had with a decat.
Custom map? That will sort it but suprised a 200 cell brought the light on.
Old Mar 5, 2013 | 12:41 PM
phil_focus's Avatar
phil_focus
Check its all sealed up ok because if there's a leak that will affect the lambda reading.
Old Mar 5, 2013 | 06:09 PM
Richsvt's Avatar
Richsvt
Thanks for replies ,had the Revo stage 2 map installed by scc performance ,guys did a diagnostic check and it said lambda sensor out of parameter ,mechanic said due to downpipe and sport cat lambda sensor just out of range ,when remapped everything ok ,asked if it would be ok at MOT time he said yes ,so I can only take his word for it ,car goes like a rocket now ,would definitely recommend the Revo software
Old Mar 5, 2013 | 10:26 PM
phil_focus's Avatar
phil_focus
Fair enough. Glad its all sorted and going well
Old Mar 6, 2013 | 10:29 PM
Deanof1973's Avatar
Deanof1973
Originally Posted by richsvt
i have just fitted a mongoose downpipe and 200 cell sport cat to my focus st and after about 200 miles the engine management light came on ,i thought wit a sport cat it wouldn't do this ,any help would be much appreciated thanks richard
hi funny i have a mongoos manafold and full stainless exhaust system and my engine managment light comes on when i turn ignition on but goes out after engine started, and car drives without any problem so can`t understnd what else the light would be on for dean
RUBY123
Oct 22, 2023 12:04 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
