L6 TPS wiring
hi there
i have a 4wd sapphire with 4wd engine loom, i'm running L6 ecu and pf01 tps (will be upgrading to L8/pf09 later in the year but want to get running first).
The loom has been adjusted for the 2wd head at some stage due the the extended temp sensor wire. As i'm running a pf01 i will need to swap the outer wires on the tps.
Which colour wire should be on top as you plug the tps connector in??? (want to check this hasn't been done previously)
Many thanks
Many thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark RS
Oct 12, 2015 06:01 AM
