Dont think my Spec r dump valve is suited to my sapp
Old Feb 7, 2013 | 06:34 PM
dean9595's Avatar
dean9595
Default Dont think my Spec r dump valve is suited to my sapp
The story is I won a spec r dump valve off eBay last week it turned up and was as described and quickly delivered so all good today I fitted it but it don't sound right it's very quite like its not building up pressure to dump ? My mate bringing in to work tomorrow a baileys twin piston to see if that is better . My question is am I right in thinking I'm sure I've seen some ware that spec r valves are for 16psi and up ? My sapps is a stage 1 265bhp if it helps ,hope some one can shed some light please
Old Feb 7, 2013 | 09:23 PM
matthewpickup's Avatar
matthewpickup
guessing here , but if its not building enough pressure to open the dump valve ie to dump it , would you not hear it trying to stop the turbo ? chatter ?
Old Feb 7, 2013 | 09:43 PM
botters's Avatar
botters
competant bodger
i think some spec r and other brand dump valves will only dump at higher boost pressures
Old Feb 8, 2013 | 08:14 AM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
I have some kind of Forge copy dump valve I think, and it doesn't dump on low revs/boost. On low boost it just chatters when I get off the throttle. But say, 2500-3000 rpm letting off the gas pedal makes a nice dump sound.
Old Feb 8, 2013 | 08:17 AM
rinus_2005's Avatar
rinus_2005
Is it a used one? maybe the valve inside has sheared/split, and cousing trouble?
Old Feb 8, 2013 | 09:46 AM
Rsmat's Avatar
Rsmat
I've got a spec R one to fit on mine... Hope 36psi is enough to ripp it
Old Feb 8, 2013 | 06:30 PM
opposite lock's Avatar
opposite lock
I run a spec r DV on a stage 1 . Its the best ive heard tbh , stays quietish at the slow stuff and has an agressive dump on full boost.
Old Feb 8, 2013 | 06:38 PM
dean9595's Avatar
dean9595
Confused.com
Old Feb 8, 2013 | 08:02 PM
arse end happy's Avatar
arse end happy
Just block it off get to know a turbo builder like me lol chatter the best sound in my view
Old Feb 8, 2013 | 08:08 PM
dean9595's Avatar
dean9595
Sounds a good idea but wanted DV and group a cone ?
Old Feb 8, 2013 | 09:53 PM
matthewpickup
have to say turbo chatter is very cool
Old Feb 8, 2013 | 09:56 PM
matthewpickup
my brother had a forge dv on his 330bhp ish t34 .48 and thats quite on low revs but works fine on higher revs too , alot of diffrent choices and specs too
Old Feb 9, 2013 | 09:14 AM
opposite lock
I run the K&N panel filter with the DV it still chatters beautifuly but subtle. Never liked loads of chatter everytime your off throttle. I find with spec r DV you can drive and create what you want rather than a set noise EACH time
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
