FRST cvh piston limit
Old Feb 7, 2013 | 04:25 PM
tom9876's Avatar
tom9876
Default FRST cvh piston limit
hi what is the limit on a standard frst piston ? i want around 250 - 270 bhp . i have steel rods . will standar pistons be up to the job ?
Old Feb 7, 2013 | 05:18 PM
Herbo747's Avatar
Herbo747
if you are going to extent of putting rods in there ect and you to achieve those figures you will be running between 15-20 psi of boost which i just wouldnt bother doing on standard pistons.
martin
Old Feb 20, 2013 | 07:17 PM
Brendan's Avatar
Brendan
struggling with reality
I wouldn't I use JE pistons and I only run up to 14 psi! giving about 185 bhp I will run NOS later this year! taking it up to about 225.
Many moons ago I burnt a hole in no. 3 as it ran a bit lean (injector partially blocked) and it did it surprisingly quickly!
now I am far more careful!
Old Feb 20, 2013 | 07:26 PM
XRT_si's Avatar
XRT_si
I believe Christian Majors first 300bhp CVH engine ran OE skimmed pistons and steel rods.
Old Mar 14, 2013 | 03:26 PM
Ben26's Avatar
Ben26
i thought he ran standard rods ??
could be wrong !
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
