what cam for my ERST? piper 285T2 any good?
so far on me RST i have bayjoo 195 chip (16psi), GRS I/C, pace rad, Magnex and K&N panel filter!
going to cam it up now i think
which do i go for? was looking at the piper 285 T2, reckon this one's best?
also if i buy this one can i use a Kent vernier pulley with it?
cheeRS
dave
cheeRS
dave
There was a article in fast ford a while ago and they featured kent, and they mentioned that the cvh34 was the ideal cam for the 1,6 but the cvh35 was good for the 1,9?
I'll see if I can find the article..
www.burtonpower.com -- KCCVH34
as berton say "ADJUSTABLE CAM PULLEY IS RECOMMENDED, 1500-7000rpm TIMING 119deg"
i got this cam cant fault it
the power is 1.5k to 7k, you dont really need the vernier pulley if you cant afford it, the cam is designed to use with standard timing marks, ive never used a vernier, and was told the other day by a tuner that its not needed.
The cam pulls hard after 3k
Ive got a kent cam in mine .And its worn already( 8k )the last owner took it to Engine advantages and they said kent r shit and they have seen a few cars in that the cam has worn .im looking at a piper cam next......
i got a piper 285t and think its a wicked cam! if i ever replace it it will be with a piper T2! cus im running 17psi the T2 would actually be a better cam to have! but the 285T is a good midrange cam!
only heard bad things about kent lately!
