Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Shiping container workshop idea
Old Feb 3, 2013 | 05:07 PM
SMILER258's Avatar
SMILER258
Default Shiping container workshop idea
Hi all, had an idea for a while, about using a 20ft shipping container for all my tools, work area and part storage, and wondered if it had any floors in the idea? As I plan on emmigrating to canada once I have done my apprenticeship and gained experience, I thought it would be good as It would all be contained in one place. It's also secure, so no dangers of break-ins And I could transport it where ever. Can anyone see any problems with the idea at all? I only want to use it for storage btw. And a second hand one is around 1500 quid
Old Feb 3, 2013 | 06:16 PM
cossiejay's Avatar
cossiejay
they are good for storage but weld or grind ( so there round ) the hinge bolts ,we had all our gear in one when I worked at the quarrys and the the scum unbolted the hidges and opened both doors in one
Old Feb 3, 2013 | 06:39 PM
spot1's Avatar
spot1
I have one inside a hanger and store all my tools in it,the only problem i have is loads of condensation just can't keep anything dry.
Old Feb 3, 2013 | 09:37 PM
SMILER258's Avatar
SMILER258
ah, so other than the small bolt issue, it's just condensation problems? What could solve that?
Old Feb 5, 2013 | 09:47 PM
clairendave's Avatar
clairendave
Dave not Claire.
Condensation can be almost resolved with a spray insulation on to the inside of the roof, make sure it either has or gets some fresh air vents, and keep them uncovered. Used to do a lot of work for a storage company, they did the above to all theres.
Maybe a ply lining could stop it too.
Old Feb 5, 2013 | 10:06 PM
james kiely's Avatar
james kiely
if you can find a old fridge container they are already insulated and do away with the conednsation issue matey
Old Feb 8, 2013 | 01:32 PM
grecian.s1's Avatar
grecian.s1
As already stated terrible for condensation wich then leads to tools you don't use often getting mouldy
Old Feb 8, 2013 | 04:58 PM
SMILER258's Avatar
SMILER258
Ah right, so if it was properly vented, I could get away with it? Cheers for the replies too!
Old Feb 19, 2013 | 12:05 PM
grecian.s1's Avatar
grecian.s1
The office ones would be ok, z little more expensive but have lights etc in already and insulated and boarded. I priced one a few weeks back and it was 1200 for 20ft one
Old Feb 19, 2013 | 06:46 PM
cossiestu's Avatar
cossiestu
Looked pretty cool on that George Clark thing on tv the other day!
Old Feb 20, 2013 | 04:52 PM
BRAMMER's Avatar
BRAMMER
Ply lining does work as we have them at work to store cardboard which is perfectly dry when removed
Old Feb 24, 2013 | 10:43 PM
stu170's Avatar
stu170
A mate of my old mans has just got 2 44 footers. Stood them side by siide and cut the sides out. Weighed that in and welded the 2 up to make a big one. Not seen it yet but will get pics when i get down his yard
Old Feb 25, 2013 | 09:00 PM
swiftyrs's Avatar
swiftyrs
no ur talkin proper size wrk shop
Old Feb 25, 2013 | 09:17 PM
car.crash's Avatar
car.crash
Make sure you up the security on the door. They are very easy to get into by either taking the door off or cutting the brackets that your locks go onto.
They echo like mad inside when your banging so insulation would sort that aswell as the condensation.
Old Mar 1, 2013 | 10:43 PM
andym's Avatar
andym
Cool, pics would be good
Old Mar 2, 2013 | 07:04 AM
Rogeyboy's Avatar
Rogeyboy
We have one at work for storage, condensation is a major issue... Reading this ive got some ideas to try n dry it out n keep it dry. Thanks all!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
Orion_Gav
Sep 29, 2015 04:50 PM
pabloXR
Sep 21, 2015 12:42 PM
