Mondeo Duratec (petrol) thermostat
Old Jan 30, 2013 | 01:15 PM
Cosnada's Avatar
Cosnada
Default Mondeo Duratec (petrol) thermostat
So, what does the electronic sensor do on the thermostat? I guess it senses stat position but which is important - open or closed and what bit of kit is it telling and what for? Does it send a signal to the BCM and then onto the HVAC unit?
If this sensor packed up is it detrimental to the running / heating / cooling of the vehicle?
Just curious
Old Jan 30, 2013 | 01:41 PM
rs2kbaby's Avatar
rs2kbaby
i would imagine if it packed up it wouldnt be sending correct info to the brain, would possibly increase fuel consumption, if thermostat still opening cant see it causing an overheating problem.
Old Jan 30, 2013 | 03:12 PM
Cosnada's Avatar
Cosnada
I agree that if mechanically the thermostat is functioning then its just like any other - what happens when you have a faulty sensor though? How does this manifest itself symptom wise?
Old Jan 30, 2013 | 06:39 PM
rs2kbaby's Avatar
rs2kbaby
symptom wise you probabally would only notice fuel consumption increase, best way is to get a cheap fault code reader that you can plug in and check, Ł20 roughly from hate to say it halfords, i feel dirty now.
Old Jan 31, 2013 | 05:45 AM
Cosnada's Avatar
Cosnada
I don't have an issue lol, just curious
wowk
Mar 30, 2021 07:49 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
