wet floorwells - front both sides
Old Jan 29, 2013 | 07:21 PM
elbow's Avatar
elbow
Default wet floorwells - front both sides
hi guys
mondeo 1.8 zetec - 105k
both floorwells are wet in the front - rubber seals in all 4 windows not great. the rear ones are worse but the front ones are starting to curlaway from the window - could this be how water is getting into the car, through the door into the wells?
Could there be any other way in?
Any pointers are very much appreciated
Old Jan 29, 2013 | 07:28 PM
TOMO's Avatar
TOMO
is there any drain holes in the top of the bulk head? ifso it could be blocked with dead leaves. it happened to my father inlaws vectra, there must of been about a gallon of water held at the top of the bulkhead because of dead leave in the drain holes.
Old Jan 29, 2013 | 07:30 PM
doga-ot's Avatar
doga-ot
Check your water level it sounds like your heater matrix behind lower dash has split
Wes
Old Jan 29, 2013 | 07:36 PM
rs2kbaby's Avatar
rs2kbaby
m reg i had done same, was scrapped in end as it had rotted out behind the frnt wings where the door pillar meets the floor pan.
shame to look at you wouldnt of thought it.
Old Jan 29, 2013 | 07:37 PM
elbow's Avatar
elbow
Thanks guys - yes i cleared out the bulkhead area just before the snow - seems ok
i will check the water levels tomorrow tho, could be interesting
Old Jan 30, 2013 | 11:51 AM
elbow's Avatar
elbow
I checked the water level - it look ok and is between min/max markers?
do you think there is any mileage in the wondow rubbers beginning to deteriorate?
Old Jan 30, 2013 | 12:08 PM
GINGExR2 T's Avatar
GINGExR2 T
Mine used to do this, ended up being water getting past the rubber at the top of the dorrs running around the frame and building up at the bottom of the door, when the car was part left side to the curb the right side got wet and vise versa, ended up cutting a small slot out of the door rubbers on the sill so the water would run out instead of in, never been wet since.
Ginger
Old Jan 30, 2013 | 12:29 PM
elbow's Avatar
elbow
Ginger, ill have a look at that too - thanks for the idea
Old Mar 1, 2013 | 06:16 AM
elbow's Avatar
elbow
quick update, i think clearing the bulkhead actually worked and the door rubbers was a red herring! thanks guys for all your input
jessie_rs
11
Jun 3, 2019 04:57 PM
Chas
Sep 21, 2015 08:57 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
C2 MAK
Aug 20, 2015 09:46 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
