My 2.1 Zetec Turbo Build
Old Apr 27, 2004 | 10:01 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default My 2.1 Zetec Turbo Build
all that dont know i have a black S2 now had a fooked engine but soon built a 2.1 zetec turbo
here is the start of the pictures of the engine
i will update most days
Old Apr 27, 2004 | 10:16 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Ahhh, your on about that pulley. Shouldent matter mate!
Looks good, keep us updated
Old Apr 27, 2004 | 10:25 PM
definetly keep us posted mate!!!!
Old Apr 28, 2004 | 09:15 AM
Roosie's Avatar
Roosie
spent some of this morning on the motor!!!!
sorry for the quality of the pics
keep losing bolts and bits
this is the car its going in
This what engine is comeing out of it
Old Apr 28, 2004 | 11:47 AM
adamS2RST's Avatar
adamS2RST
Looks good Stu. Keeps us posted! get it done for the summer!
Old Apr 28, 2004 | 11:55 AM
What work do you have to do on the mounts to get a zetec block into a mk4? I am thinking of doing this conversion to my mk4 cabby.
any info would be appreciated
Thanks
Old Apr 28, 2004 | 02:04 PM
Roosie's Avatar
Roosie
just cut part the mount on a weld it on at a diferent angle with anotothe hole but i know 3 zetec conversions that have used the 2 bolts to hold it in so u dont need to do anything which i maybe doing,
cheers adam i got these sump bolts here for your engine
Old Apr 28, 2004 | 05:13 PM
adamS2RST's Avatar
adamS2RST
Yea, I must pick them up before we forget about em again and they get lost or something! lol. I need to get bits off Ryan too
Old Apr 29, 2004 | 09:45 AM
Ferd's Avatar
Ferd
Default Zetec Turbo
Hi Stu
A have a blanking plate I made for the old oil breathing hole if you’re interested.
Ferd
Old Apr 29, 2004 | 12:17 PM
Roosie's Avatar
Roosie
yeah mate how much do u want for it i was gonna look for a core plug in that size
Old Apr 29, 2004 | 04:48 PM
Ferd's Avatar
Ferd
Default Zetec Turbo
Core plug Ha Ha
As it's you you can have it for a Fiver but your have to wait until Sat afternoon before you can get it.
Ferd
Old Apr 30, 2004 | 11:44 AM
PhilM's Avatar
PhilM
Default Re: Zetec Turbo
Originally Posted by Ferd
Core plug Ha Ha
And what is wrong with using a core plug then? Id like to know since a few engines I have built have used them, and I think I must be blind to the problems they are causing?
Old Apr 30, 2004 | 12:11 PM
Ferd's Avatar
Ferd
Default Zetec Turbo
I hope I have not upset you PhilM
It’s just I was unawares you could get a Core Plug that size. And I guess you put 3 bolts in the holes as well then.
But I do think a nice alloy plate would look better.
Ferd
Old Apr 30, 2004 | 12:47 PM
Roosie's Avatar
Roosie
pjil u havent got a clue what core plug or what car it come from??
Old Apr 30, 2004 | 01:50 PM
PhilM's Avatar
PhilM
No Roosie, I can get you one tho?
No need to put bolts in the holes.......as they dont penetrate through the block anyway
Old May 2, 2004 | 06:45 PM
smartrs's Avatar
smartrs
stu that looks a mint rs you got there you did well there looks like some one has spent some time looking after that
Old May 3, 2004 | 06:37 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Old May 3, 2004 | 08:43 AM
loooovin it mate keep up the good work.
Old May 8, 2004 | 09:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
Old May 8, 2004 | 09:35 AM
L33 BYT's Avatar
L33 BYT
U Fookin what. I thought he bought your old one.
Old May 8, 2004 | 09:44 AM
Roosie's Avatar
Roosie
Old Jun 1, 2004 | 09:25 PM
gavintwopies's Avatar
gavintwopies
the engine looks good m8 but i have a few questions?????
1*are those vauhall 16v pistons or calibra turbo pistons?
2*are you making/using any adaptor plates to get the inlet to fit the 16v head and space the throttle body up as it dont look like you have them on by the photo?
3*what management are you going to use?
4*how are you going to get around the throttle cable braket hitting the back of the head?
As you might gather by the questions i'm also looking in to making my own zetec turbo
only i'm thinking off keeping it 1.8 for ease and convenience and besides im only hoping to get 200bhp max if i'm really lucky (on a good day with the wind behind me )
If it works out good in the end i might put a bit more money into it and go 2.1 in the end
Old Jun 1, 2004 | 11:15 PM
escort1989uk's Avatar
escort1989uk
might as well go 2.3 now that the one that is getting more popular
Old Jun 2, 2004 | 09:22 PM
Roosie's Avatar
Roosie
Calibra turbo mate as im going to be running 20psi
its hard to see but there is a spacer plate there its very thin u dont need much
Secs
Havent thought about that yet not much of a issue
1800 are crap really to be honest yeah 200bhp is ok but u get bored.
any more info i shoul dbe able to help[/b]
Old Jun 3, 2004 | 05:19 PM
gavintwopies
well my main concern is that i've been told that once you get over 200 bhp with the amount of torque that goes along with it, the gearbox is the weakest link and things start going pear shaped and i dont fancey swapping gearboxes every 2-3months or paying 1500 for a quaife box.
the other ting i forgot to ask was about the pistons you have used how did you come to get hold of them as they look used????
and if so how much did you give for them???
Old Jun 3, 2004 | 09:39 PM
Ferd's Avatar
Ferd
Default Zetec Turbo
Gavintwopies
The S1 and S2 gearboxes are good for 200 to 250bhp and after that they don't last very long like you said.
I am using a 130 ps 16v Zetec for my convertion it has higher profile cams and oil jet under the pistons. it should make 200 bhp easy as long as i keep the charge air temp down. so i will put a large intercooler on.
ferd
Old Jun 4, 2004 | 02:37 PM
Axxess's Avatar
Axxess
Have you kept standard valve springs? Can you use standard spark plugs too?
Old Jun 4, 2004 | 02:50 PM
adamS2RST's Avatar
adamS2RST
Stu, what's the progress on this now? is it in yet? Aint seen u!
Old Jun 13, 2004 | 04:16 PM
Roosie's Avatar
Roosie
engine is all built
right now what am i going to do with it
Old Jun 13, 2004 | 04:17 PM
Roosie's Avatar
Roosie
Old Jun 14, 2004 | 09:05 PM
ian r's Avatar
ian r
sell it to me ????
Old Jun 15, 2004 | 06:15 AM
Roosie's Avatar
Roosie
Originally Posted by ian r
sell it to me ????
You offer me a price and i might!
Old Jun 15, 2004 | 06:44 AM
Ferd's Avatar
Ferd
Default Zetec Turbo
Put in that car of course!!! Or any car.
If not let me know how much you want for it.
FERD
Old Jun 15, 2004 | 07:24 PM
Roosie's Avatar
Roosie
Old Jun 15, 2004 | 07:26 PM
Roosie's Avatar
Roosie
and this will be the managment
Old Jun 15, 2004 | 07:30 PM
ian r's Avatar
ian r
stu would have the whole lot off u but just rebuilt mine so cash is low at the mo
Old Jun 16, 2004 | 08:32 AM
gavintwopies
how have you mounted the inlet to the head have you just re-tapped the head to match the inlet or have you got studs in your adaptor plate while mounting the adaptor plate to the head using the original mounting holes ???? hence no re-tapping required of the head
just i'm in to minds of which way to do it myself????
and i'd rather use the tried and tested way
Old Jun 16, 2004 | 06:43 PM
Roosie's Avatar
Roosie
the head got retapped mate dont like idea of plates tbh
Old Jun 16, 2004 | 10:08 PM
Ferd's Avatar
Ferd
Default Zetec Turbo
Have you tried putting the Throttle body on yet then?
I think your need a plate to raise it a bit m8.
Old Jun 17, 2004 | 05:16 AM
Roosie's Avatar
Roosie
nah ferd it fits ok ive checked alrady
