closed loop turbo ecu wasted spark help please
Old Jan 15, 2013 | 07:46 PM
garrett's Avatar
garrett
Default closed loop turbo ecu wasted spark help please
hello i bought myself a sierra cosworth 4wd
and the previous owner tells me its got a closed loop system from MSD and i think also the wasted spark
can some one tell me which parts are included and what has been done/changed to fit this system
and also is it normal to do the lambda in the exhaust housing of the turbo (see pic)
and can this turbo still be used for a 2wd know
lots of questions and i hope someone can help
thanks
Old Jan 15, 2013 | 10:21 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Your lambda looks right.
W/S wise.
You have now got 2 ignition amplifiers, 2 cyl's each. A coil pack instesd of a old coil.
The W/S driver inside the Ecu. The adaptor loom for the amps, 2 wires to Ecu and coil. No need for the distributor for the spark plug leads, but still feeds IIRC to the phase sensor, and coil pack type leads.
All in all a dam good piece of kit.
Is the turbo for the engine in the pics?. Looking at it (from the pics weird angle), it looks like a 4x4 manifold fitment, but I might be wrong.
Old Jan 16, 2013 | 04:22 AM
garrett's Avatar
garrett
thanks for the replay
yes it is for this cosworth a 4x4
do you think this turbo will also fit the 2wd if i cange this with a 2wd exhaust housing
thanks
Old Jan 16, 2013 | 09:30 AM
Paul_RS's Avatar
Paul_RS
You just need to rotate the housing for it to fit a 2wd manifold.
You have wasted spark fitted - that's why nothing is connected to your distributor and you have a coilpack mounted to the inner wing
The lambda sensor is fitted in the exhuast housing by Ford.
Old Jan 16, 2013 | 10:51 AM
garrett's Avatar
garrett
Thanks for the help
But i know that the 2wd doesnt have this lambda
Is it possible to change the exhaust hausing or maybe there is anouther Way
Maybe its oké to leave it disconnected
When i want to fit this turbo to à 2wd
Old Jan 16, 2013 | 11:25 AM
Thanasis's Avatar
Thanasis
if you fit the 2wd exhaust manifold with your 4x4 turbo exhaust housing you will need to weld adaptor for the sensor to the down pipe,because chance the exhaust housing place!!
Old Jan 16, 2013 | 01:16 PM
garrett's Avatar
garrett
Isn’t it easer to just change this 4wd turbo exhaust housing with a 2wd turbo exhaust housing
Old Jan 16, 2013 | 01:26 PM
Thanasis's Avatar
Thanasis
use a lot WD40 let it about 5 minutes and then with a hard caoutchouc hammer knock the housing,if it does not unstick,heat the housing around,and knock it again!!
Old Jan 16, 2013 | 01:32 PM
garrett's Avatar
garrett
so it is possible to fit the 2wd turbo exhaust housing to a 4wd turbo???
Old Jan 16, 2013 | 01:33 PM
Thanasis's Avatar
Thanasis
yes they are the same!
Topjoe9
Aug 20, 2015 02:38 PM
Escortdriver1
Aug 19, 2015 09:02 PM
IAN RS2k
Aug 18, 2015 07:51 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Escortdriver1
Jul 31, 2015 02:36 PM
