engine note changed
Old Jan 15, 2013 | 06:05 PM
Calster53's Avatar
Calster53
st driver
Default engine note changed
hi all
i started my 98 st24 for the first time today she has been sitting for about 4 months anyway she started fine moved her around the corner to give her a good clean finished what i was doing when to the engine bay checked all of the conector plugs to make sure tha they were all in corectly 1 was abit loose anyway started her up and now the engine noise has changed to a deeped growl and a slight judder any thoughts.
and now my middle air direction knob dosent work you can turn it but its stuck on the demister setting
thanks
Callum
Old Jan 15, 2013 | 06:22 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
funnily enough iv been getting this happening for a while on my focus and i think its a dodgy imrc. inlet manifold runner control. its usually a simple fix on the focus but not sure on st24 if they are the same. its the only thing i can assume that would change intake noise.
Old Jan 16, 2013 | 04:14 PM
Calster53's Avatar
Calster53
st driver
just been to my macanic and he is saying that it is my coil pack has gone down so new 1 is on order so fingers crossed it solves the problem
cameron2
Aug 25, 2015 07:18 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
