Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Snap on battery's
Old Jan 11, 2013 | 09:36 PM
steveo135's Avatar
steveo135
Default Snap on battery's
Hi guys, I have a snap on battery operated drill and impact gun, the battery's will no longer hold charge. The local snap on dealer will not entertain the fact they are dead, where is the next best place to go to get them either stripped/replaced or recharged if this is possible.
Any help would be great.
Old Jan 11, 2013 | 10:04 PM
IanC's Avatar
IanC
qite easy to repair i have repaired lots of baterys will be a dead cell in the battery can make one good battery out of the 2
Old Jan 11, 2013 | 10:09 PM
steveo135's Avatar
steveo135
Default Battery's
How will I find out what cell is dead, as they won't hold any charge at all. The red warning light comes on the charger base.
Thanks
Old Jan 11, 2013 | 10:41 PM
IanC's Avatar
IanC
best thing to do is take the batt apart and put a multimeter across each cell one at a tme and they should all be holding a similar voltage execpt the fucked cell then out of the other batt take a good cell and solder it in place of the dud cell hope that explains it i can pm u my num if your stuck and explain it a bit better over the fone if you like
Old Jan 11, 2013 | 11:27 PM
steveo135's Avatar
steveo135
Default Battery's
I'll put both battery's on charge tomorrow and then do the checks.
Thanks for the info
Old Jan 12, 2013 | 09:27 AM
Mark 3D's Avatar
Mark 3D
Moderator
someone also advertises on ebay to recell batteries.
Old Jan 12, 2013 | 11:50 AM
IanC's Avatar
IanC
It's easy enuff to do your self just buy another scrap batt off eBay for cells
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
