my st170
Not the most exciting or impressive car on here but I have had some good days out in it so thought I would post some pics as there are a few similar st170 threads on here.
I have had a lot of help and guidance from other people on various forums and always appreciate advise and suggestions
Spec:
BC racing coilovers with adjustable top mounts can be cornerweighted and adjusted for camber
Coilovers set up for optimal handling on track at Jamsport
Dampers can be adusted on the car with top adjusters front and rear
Rear upper Jamsport strut brace bolted into rear wings
Rear lower whiteline adjustable sway bar
Front eibach arb
Omp front lower strut brace
E-tech front upper strut brace
Eibach rear camber bolts
Magnex 4" catback stainless exhaust
Miltek decat pipe (mapped to run without EML coming on)
Alternative scorpion sports cat (for MOT)
Dreamscience stratagem remap
Currently mapped on RACE95CAIS map which allows you to run a decat without putting EML light on
K & N typhoon induction kit with heatshield
Recent new cambelt with exhaust cam retimed for acceleration
Scangauge hardwired with OBD splitter cable to allow use of 2 OBD device
Goodridge braided hoses front and rear
Front black diamond combi drilled and grooved discs
Front ferodo racing ds2500 pads
Motul race fluid
Cobra monaco pro drivers and passenger front seats (in FIA date)
Cobra tailored subframes with sliders and seatbelt pretensioners and seatbelts for road driving
Cobra evo (trs) 5 point FIA spec 4" harnesses for driver and passenger (in FIA date)
OMP wrc steering wheel
Foglights removed for venting
Trim stripped out
black team dynamics pro race 1.2s with r888s
oz superturismo wrcs with kumho v70as
Omex culbman rev limiter with launch control
probably more I can't remember
Thanks to companies who have worked on it:
Jamsport
OC motorsport
JC performance
Plans:
Custom cages roll cage
Improve fueling system
plumb in fire extinguisher
Wire up battery isolator/ kill switches with interior and exterior pull cords
More track days
Some pictures:
Any advice or suggestions welcomed
al
Spec:
Front eibach arb
Motul race fluid
Trim stripped out
Jamsport
OC motorsport
JC performance
Plans:
More track days
Some pictures:
al
great to see you post it up aj. how do you find the brakes? cope no problems??
what issues are you having with fueling?? also when i ran my blue one at llandow in sept i leaked gearbox fluid apparently from a breather hose my local garage said. have you ever had this problem? i havent looked at it my self but will be looking for a cure to this happening in silver one
I have never had any issues with the brakes. As you know I take it fairly easy on track but they have always done fine and I have never had any issues with fade. I have slammed on the brakes from decent speeds at Silverstone and they have been fine.
I would really recommed the ferodo ds2500 pads they make a huge difference to the braking power. If you fit them you will feel the difference when you brake hard. I used to pull up too soon when I was first getting used to them.
If the power is upped then I might consider other options but for now I reckon the brake setup I have is spot on.
I have had problems with fuel surge/ starvation a few times on track. This might be more due to my particular car as I have had 3 fuel pumps in the last few years but reckon it might be worth uprating the whole fuel setup.
Never had any problems with leaks other than washer bottle.
Other than that it has been reliable enough on track and it has always got me home. The only problems I have had have been down to my driving rather than because of the car.
Will be keeping an eye on all the focus threads plus valleys fiesta thread so we can all co-ordinate a day at Llandow hopefully as would be good to get them all out on track and despite the distance I find it a decent day out
al
whats the symptoms of fuel starvation for your car? i have had problems with my silver one since buying it which i think was fuel starvation. only occaisionally when the revs got up it would die flat and would not accelarate until i back off then back on. got a replacment pump but its dated 2002 and mine is 2003 so thinking will it be no better than one i got.
In long corners it starts to surge like the "kangarooing" you get from a dodgy pump basically what you describe. I keep looking at uprated pumps but have never got around to fitting one.
cheers mate
al
al
lolTold you to get a fuel swirl pot :/
ajc just get everything i posted you to get then you wont have any problems
lol (oooo i just rembered where you can get a good brand new one for Ł50 )valleys fiesta? ajc after three years you still dont know its valleys focus lol, I dont even know where my threads gone on here, NOoO dont say that or im going to have to pull the shity 1.7 out of there and fit my lovely 2.0 or your all going to kill me, Well only nevs is going to kill me the st will try to get away but wont lol
Andypandy260
Sep 23, 2015 10:28 PM
