Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
1.8 TDCI major misfire like symptoms
Old Jan 10, 2013 | 06:01 PM
cj2's Avatar
cj2
Default 1.8 TDCI major misfire like symptoms
Hi,
Been having some trouble with my 2006 Focus 1.8 TDCI over the last few weeks. Started on a drive to work, when I hit around 3000 rpm in 4th the engine cut in and out repeatedly. With the throttle buried the sypmtoms got worse, but eased right back I could just about make a little more progress through the rev range.
The last few weeks the issue has come and gone a few times, but in recent days seems doesn't seem to be going away and is getting much worse. Now struggling even in 2nd to get past 3000rpm, and by the time up to 4th I can't get much over 2000.
I'm going to take the car into a local garage on Monday, but not too hopeful of them finding a solution. I haven't had any engine warning lights come on (and presumably no fault codes).
I have read of EGR issues, but ruled this out due to lack of smoke, car seems to be running cleanly enough. I think it must be a fuel issue of some kind. I'd love it to be the fuel filter, but thinking more along lines of fuel pump or injectors.
Can anyone give a heads up if my guesswork seems reasonable, or if it would be easy to rule out any of the above given the symptoms described?
Old Jan 10, 2013 | 06:07 PM
the_frozen_one's Avatar
the_frozen_one
More than likely the filter, do you run it to the fuel light often? Use supermarket fuel?
Pump is very very robust, injectors usually surpass 150k miles even with neglect ie nasty fuel, lack of filter changes etc etc
Old Jan 10, 2013 | 08:12 PM
cj2's Avatar
cj2
Yes supermarket fuel most of the time and thinking about it, the initial symptoms and recent worsening both tie in with filling up at a certain local supermarket.
Thanks, will give it a go and hope it fixes the problem!
Old Jan 10, 2013 | 08:16 PM
the_frozen_one
Supermarkets often cock up diesel blends.
If you have a shell/bp/texaco etc near by I'd strongly advise issuing that instead in the price is close. An extra £1 or so each fill up will save £100s in the long run
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
