Escort mk4
Old Jan 8, 2013 | 07:12 PM
chrisgcombi's Avatar
chrisgcombi
Default Escort mk4
Hi all , new member . I have a modified combi mk4 van and is currently running an xr3i engine . Thinkin of zetec ing her as cant afford an rs conversion even though she is screamin out for one ? . Could anyone let me know if the engine mounts are the same etc , i know i can get a cvh efi plate for the zetec manifold and also are the drive shafts off my mk4 ok to go on the zetec . Thanks chris
Old Jan 8, 2013 | 07:17 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
I think you have to lift the engine mount up on the inner wing for it to bolt in, but dont hold me to it
Old Jan 8, 2013 | 07:25 PM
project rs's Avatar
project rs
your drive shafts will be ok as you can use the current gearbox you've got with the zetec engine and you can adapt the cvh engine mount to work on the zetec engine
Old Jan 8, 2013 | 07:29 PM
chrisgcombi
Default Escort combi
Thanks peeps all info really appreciated .
Dr. Ickxs
Sep 15, 2015 10:15 PM
Chopshop85
Sep 12, 2015 06:42 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
