poor starting cossie management cvh
Old Jan 8, 2013 | 09:14 AM
B19 JUB's Avatar
B19 JUB
Default poor starting cossie management cvh
hey people just wondering if someone could chuck some ideas my way about the prob im having.i recently bought an orion cvh turbo with cossie management which i believe its an l6 ecu.the prob im having is it cranks for ages when cold before it eventually fires up.
its still running a dizzy just wondered if theres any common things to look for?
many thanks in advance
Old Jan 8, 2013 | 10:07 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If it's fine when hot then I'd take a stab at coolant temp sensor.
Old Jan 8, 2013 | 10:37 AM
haz87's Avatar
haz87
Phase sensor breaking down (usually wires)
Old Jan 8, 2013 | 10:38 AM
haz87's Avatar
haz87
How does it idle once it has started Marc?
Old Jan 8, 2013 | 10:39 AM
haz87's Avatar
haz87
Coolant Temp Sensor Checking
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) Check resistance between pins 29 and 11. Should be 800 to 5000 ohms (depends on temp). If outside this range, check sensor and/or wiring.
Old Jan 8, 2013 | 07:35 PM
B19 JUB's Avatar
B19 JUB
once its started haz it runs fine.just take ages to crank and stinks of fuel once its started.i believe the guy i bought it off told me it had a poor cold idle but seems fine to me
Old Jan 8, 2013 | 09:29 PM
B18PWR's Avatar
B18PWR
Poorly mapped in this zone ?
JoeyBoyden
20
Aug 22, 2015 03:23 PM
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
