Fuel filter removal problem! Help!
Old Jan 6, 2013 | 06:40 PM
Longdog3004's Avatar
Longdog3004
Default Fuel filter removal problem! Help!
Hi I'm trying to remove my B-reg sierra XR4i fuel filter and when trying to undo the inlet onion the nut is stuck solid!
I've strayed WD all over it left it over night and tried again today and the filter itself is starting to buckle rather than loosen!
I'm using pair of grips holding the filter and spanner on onion nut!
Any ideas guys?
Old Jan 6, 2013 | 07:04 PM
cabriolet's Avatar
cabriolet
i would cut the filter apart until i could get to the thread then hacksaw/file away .the metal until it released
Old Jan 6, 2013 | 07:17 PM
Longdog3004
Cheers mate
Old Jan 6, 2013 | 07:20 PM
adam151082's Avatar
adam151082
Is there not a place for a spanner on the filter next to the nut. If it fails try mat lewis for new nuts and bolts and just cut it off.
Old Jan 6, 2013 | 08:00 PM
Longdog3004
Yeah there is but it's starting to buckle on that bit!
I think cutting it off might be easier cheers
Old Jan 6, 2013 | 08:20 PM
Get some heat on it
lol.
Old Jan 6, 2013 | 09:03 PM
Longdog3004
Lol did think of that but had visions of a smouldering car
Old Jan 6, 2013 | 09:16 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
I bent the pipe right round but got the filter off... need a new pipe now.
I guess you could go though it with a screw driver to hold it but fuel will pour out.
Old Jan 6, 2013 | 09:23 PM
whizzisat114's Avatar
whizzisat114
Id warm the filter housing with a heat gun as the alli will expand faster than the steel fitting
Then try again
Old Jan 6, 2013 | 09:33 PM
Longdog3004
Dont think a screwdriver will hold it if a pair of grips wont?.?
Bit unsure about using a heat gun!!!
Might try pouring a kettle over the housing see if that works!!
Old Jan 6, 2013 | 09:38 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
I mean pierce through so it holds it.
Why not just cut the pipe and start again with a new bolt?
Aug 29, 2015 08:16 PM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
