1200 bhp escort
Old Jan 6, 2013 | 10:39 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
Default 1200 bhp escort
HI
have you seen that 1200 bhp escort in performance ford i think that has just pushed the bar just a bit out of reach now but well done to him ,come on mark ,harvey , julian show him what the brits can do lol
mark
Old Jan 6, 2013 | 11:28 AM
DAN400's Avatar
DAN400
but will it stay together??
hav nt bought performance ford in years, must get it today and have a nosey
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I'm shore there's been a few over here with over a 1000bhp lol but if the likes of Julian and mark can't do it on pump or race fuel to a usable and reliable standard I very much doubt its possible! Plus a lot of these cars seem to be out and out drag cars with power right up the rev range so I dare say in the real world on the road would be shit!
Old Jan 6, 2013 | 11:30 AM
Fullflush's Avatar
Fullflush
I think Julian or NMS might be the only ones able to pull a rabbit like this out of the hat.
Rod has tried for years and got nowhere near
Old Jan 6, 2013 | 11:33 AM
ajamesc's Avatar
ajamesc
i think that's because as a usable engine in a road car 850 ish bhp is as far as it will ever go!
Old Jan 6, 2013 | 11:36 AM
Mark Shead's Avatar
Mark Shead
Put Rods on methonal and its 1000hp if the HG lasts its that easy, Getting 800hp on pump is much harder.
Mark
Old Jan 6, 2013 | 11:50 AM
MK MOTORSPORT
Mark
hi mark
whats hg ?
also if engines on pump fuel wont stay together at 800 what is it in methonol that makes an engine stronger able to take 1200
mark
Old Jan 6, 2013 | 11:51 AM
Sonic Boom's Avatar
Sonic Boom
Mark
Mark my 3 Door is 550bhp how much more would you get out of it just by mapping it on Methonal?
I know you'd probably need to know more information on the engine but is it lineer to the BHP the car is already producing?
Cheers Rich
Old Jan 6, 2013 | 11:55 AM
JamesH's Avatar
JamesH
Originally Posted by MK MOTORSPORT
hi mark
whats hg ?
mark
Head gasket
Old Jan 6, 2013 | 11:57 AM
Mark Shead's Avatar
Mark Shead
hi mark
whats hg ?
mark
Look at the make up of that fuel and this will tell you everything,
Hg I have one in mind for the 1000+hp engine but other changes are needed to make it work and I decided not to use it on Rods.
Mark
Old Jan 6, 2013 | 11:58 AM
Mark Shead's Avatar
Mark Shead
Cheers Rich
Its not good stuff to use and you need to make other changes and double the size of your fuel supply.
Mark
Old Jan 6, 2013 | 11:59 AM
MK MOTORSPORT
Originally Posted by JamesH
Head gasket
hi james simple when you know lol ,
doh lol
how can the head gasket last another 400 bhp just because its on methonal
mark
Old Jan 6, 2013 | 12:00 PM
Jasu's Avatar
Jasu
And I'm pretty sure that the head gasket is not the problem.
The biggest problem seems to be money and durability. Surprise, surprise.
Old Jan 6, 2013 | 12:02 PM
Sonic Boom's Avatar
Sonic Boom
Mark
My Dad used to run in his Race Car (Cooper 500) on Methonal 80% to 20% Nitromethane. Course all he had to do was drill the jets out on his carburettor
Rich
Old Jan 6, 2013 | 12:06 PM
Mark Shead's Avatar
Mark Shead
Rich
That fuel should have been in a rocket not a Cooper.
Mark
Old Jan 6, 2013 | 12:07 PM
MK MOTORSPORT
Mark
hi mark
i dont understand how a fuel can make a crank rods pistons etc stronger ,if a 800 hp engine brakes on pump fuel why is it stronger on methonal ,not being funny i just dont understand ,on the block geoff has done, he says he has done it like bdt ie fire rings and o rings round the rest ,would a recess in the head and a copper ring and the the liner protruding so it bites in the copper ring then o ring the rest so studs are just pulling down on a smaller area than trying to clamp the full surface of the head block the pressure on the rings will be a lot higher for the same torque then if on the full surface of the deck
mark
Mark_'s Avatar
Mark_
Im sure then answer is pretty straight forward, but how comes WMI isn't more commonly used in the Ford scene?
I know the VW boys tend to run it on bigish power 1.8t's.
Most run Devil's Own
Just wondered why its not used here?
Old Jan 6, 2013 | 12:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hi mark
mark
It doesn't make the engine stronger... It can make more power because it has a higher det threshold, the engine (rods, pistons, crank, block, etc.) will still need to be able to cope with it of course.
Old Jan 6, 2013 | 12:16 PM
Sonic Boom's Avatar
Sonic Boom
Mark
There was a crazy bloke call Tim Cameron who used to run more Nitromethane than Methonal in his Cooper.
Never stand behind a car running Nitromenthane it's like being tear gased.
Rich
Old Jan 6, 2013 | 12:30 PM
MK MOTORSPORT
oh ok thanks for that , thats what i thought ,what did the f1 turbo cars use for fuel when they were making 1500/1600 bhp for qualy and 1000bhp for the race and was they 1600/1800 cc
mark
Old Jan 6, 2013 | 12:33 PM
Mark Shead's Avatar
Mark Shead
Correct and it has 50% oxygen and burns cooler which also means a normal water system struggles to get up to temp.
Mark
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
twin turbo setup is all that's needed, so the big power can run on a hue turbo so far less pumping losses.
obviously lots of billet and fine machining to keep it together.
Old Jan 6, 2013 | 12:36 PM
ben_frst's Avatar
ben_frst
cant agree more i would like to see how much faster a that escort is compared to a 6-700 hp car built by the likes of julian/mark/harvey/whoever tbh
and also if it would last more than a couple of hours at that power
I've not even seen the car and tbh not interested i doubt any ground breaking development has been made
the proof is in the pudding lol
Old Jan 6, 2013 | 12:46 PM
MK MOTORSPORT
hi
i think in the mag it said it was doing 8 second quarters ,if you look at the feature it looks like it has a few things on it not done before
mark
Old Jan 6, 2013 | 12:49 PM
JonnyBravo's Avatar
JonnyBravo
If it runs 8.3 1/4's then I would say its a LOT faster than anything they have all built, thing is IMO like Rods car its a one trick pony and very few people are interested in that sort of thing, you are never going to have that sort of power reliably in a road car, well not from a YB.
Old Jan 6, 2013 | 12:55 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Didn't Andy Forrest old spec engine Subaru run methanol?
No intercooler as its on methanol so no need?
Old Jan 6, 2013 | 01:03 PM
scoooby slayer's Avatar
scoooby slayer
and that in itself is phenomenal imo 850 reliable as can hp from a little 4 pot
Old Jan 6, 2013 | 01:14 PM
ajamesc's Avatar
ajamesc
Rods car is far from a one trick pony lol so it dose top speed runs! More important is the distance in which it dose them runs as that shows how fast the car is from take off till maxed out! In the real world on the road any car with 600+ bhp that has matching torque all low down and can get it on the road is playing a totally different game to at a guess any road car or road bike you will have ever been in or on lol. Striped out drag cars are a totally different thing just because a car is fast up the quarter mile don't mean it will be fast on the road in 4th at 70 mph
Old Jan 6, 2013 | 01:26 PM
costina's Avatar
costina
Live long and prosper!!
All from a modded cortina block
Regards head gasket issues why is'nt wire ringing or coopers rings used anymore surely this would be a better option.
Old Jan 6, 2013 | 01:32 PM
JonnyBravo's Avatar
JonnyBravo
I'm fully aware of the performance figures which are VERY impressive. I'm far more impressed by cars like the AG Focus that can still put down incredible acceleration times and be one of the fastest things round a circuit.
If I wanted a very fast road car I would just buy a Porsche turbo and have it remapped.
Old Jan 6, 2013 | 03:19 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
What has Rod tried I may know more than most what he tried to do .
In 2004 i asked Mark to build a 600bhp road engine it made 613bhp on pump fuel it ran untill it cracked a Block in 2006 running a 300shot of Nitrous.
I then asked for a 800bhp road engine. The race fuel head gasket problem took 2 years to solve but been OK since 2008 . It was the first & probably still the only YB to make 800bhp on road fuel, it has not yet done a gasket on pump fuel or cracked a block .
Its rather pointless comparing my baby with a Methanol drag engine , my ports are too small, the cams not wild enough & my Turbo small compared to the 45 on that drag engine. One will be great at 8secs passes on 100% WOT the other will take 40secs at 100% WOT .
My aim since i retired from setting RS Topspeed records, is to help others who are interested in that discipline. Its time for the next crop of record setters to emerge im older than Mike R's hairstyle & have had my day.
Im involved with several 2013 attempts one with a rival Tuner, lets hope Sheady dont find out who .
Old Jan 6, 2013 | 03:25 PM
It's Czech Mate's Avatar
It's Czech Mate
Originally Posted by Rod-Tarry
I then asked for a 800bhp road engine. The race fuel head gasket problem took 2 years to solve but been OK since 2008 ..
Was the 4 years since 2008 sat in the garage gathering dust a tough enough test though? I've got no idea how you can say any incarnation of your car in recent years is everyday reliable as according to your posts its always laid up waiting for parts
Old Jan 6, 2013 | 03:34 PM
I will have a read of the feature later on.
Very impressive figures.
Old Jan 6, 2013 | 03:58 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Do you really need another 500hp to gain only 1 second in drag racing? I'm pretty sure ag focus ran a 9.3 at totb and that escort is only 1 second quicker.
Old Jan 6, 2013 | 04:00 PM
botters's Avatar
botters
competant bodger
mark
if i remember correctley on one of the cosworth films i watched regarding the f1 engines that they built, some were running upto 100psi of boost!
Old Jan 6, 2013 | 04:04 PM
frsjon's Avatar
frsjon
Rich
me and a few mates found this out at the pod a few years ago.. watched this nitro car go up the strip from the vip balcony,felt shit/dissy for a while lol the drivers wife was up there with us and said it was the nitro!
Old Jan 6, 2013 | 04:07 PM
costina's Avatar
costina
guess you would have to use a oil gauge to read boost for that one
Old Jan 6, 2013 | 04:22 PM
lee2cossies's Avatar
lee2cossies
There's clearly traction issues with the escort if u look at the run and the terminal speed is 178mph where the ag focus was 150mph ish. It run 8.3 seconds on it's first outing so imagine it will go faster with further development.
Old Jan 6, 2013 | 04:24 PM
lee2cossies
The block cracking I thought was the biggest problem with huge power yb's? Hence this new block design from Geoff page? Still good to see tuners pushing the boudaries with the old alloy head pinto.
Old Jan 6, 2013 | 04:27 PM
lee2cossies
I'm sure andy couldn't get good results with the methanol and went back to intercooler and race fuel, it then went faster than ever,8.9 seconds. His latest car with a svx Subaru v6 has now done 8.4 seconds!!!
