2wd cossie discs onto erst
Old Mar 10, 2005 | 05:40 PM
ballin's Avatar
ballin
Default 2wd cossie discs onto erst
ive got the brackets and disks to do this, but that it.
do i need different bolts or ought?
if so anyone know what?
thanks
Old Mar 10, 2005 | 06:19 PM
radiant red's Avatar
radiant red
you would only need longer wheel bolts if the part of the disc between the wheel and the hub were a fair bit thicker than the original disc.
Old Mar 10, 2005 | 06:33 PM
AJC's Avatar
AJC
there is info here if it helps
www.chardcars.com
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
rsstav
Sep 7, 2015 04:43 AM
jc1989rs
Sep 5, 2015 08:09 PM
